Glass table top thickness
Forum topic by sry posted 172 days ago 476 views 0 times favorited 4 replies Add to Favorites Watch
View sry's profile
sry
137 posts in 505 days
172 days ago
Topic tags/keywords: glass table top thickness epoxy
I’m designing a pub table as a wedding present, and have a question about what thickness I should use for the glass table top. The design will be conceptually similar to this table witha 24” diameter piece of glass supported all around the circumference by the bordering wood.
The clear part of the top will be layered like this from top to bottom:
Tempered glass
Clear poxy (mirror coat) with embedded objects (beer caps) – 1/4” thick
The question is will the epoxy add any strength to the glass (ie letting me get away with 1/4” glass) or should I still use 1/2” glass just to be safe?
Thanks
-- Steve -- University Heights, Ohio
View Julian's profile
Julian
695 posts in 423 days
172 days ago
Epoxy will not add strength to the glass. Make sure to use tempered glass. As for thickness, I would think 1/4” tempered glass should be fine for a tabletop that size.
-- Julian, Park Forest, IL
View Rev_John's profile
Rev_John
17 posts in 786 days
171 days ago
I agree. I have repaired glass tables and almost off the the tops were 3/8th with a few a speck bigger. I think that you would be wise to go with a thicker class, after all, items will not always be put on lightly. Make sure it is tempered, and no Epoxy will add nothing, but the beer caps touching the glass directly could create a striking point and weaken the glass, whereas the wood helps custion heavier hits on the glass.
-- John from Jackson, Michigan
View sry's profile
sry
171 days ago
Thanks guys
I think I’ll probably end up using 1/2” glass just to be safe
View bentlyj's profile
bentlyj
790 posts in 367 days
171 days ago
There’s no need for 1/2” for a table that size. I have a coffee table that has a square top 42×42 and it’s 1/4” tempered and has been beat and banged pretty good. I have done a lot of glass work, displays for stores, jewelery cases, etc…. 1/4” is plenty in my opinion. I think 3/8” not tempered would also be strong enough.
