| Forum topic by tacodan | posted 153 days ago | 214 views | 0 times favorited | 5 replies | ![]() |
153 days ago |
Topic tags/keywords: question |
153 days ago |
actually a router table would be the way to – NOT do it :) much easier with a handheld router, and a circle guide. set the guide in the middle of the circle, set it’s radius to be the one you wish your circle to be, use a 3/4” straight bit, and set depth of cut to 3/8”, and start routing – take 1/8” on each pass, and you should be done and done in no time. do a search for circle-guide here and google. there are some store bought ones, and there are homemade one that you can make – a very useful jig to have if you’re using a router – when you need it -there’s nothing better. EDIT: you can see my Bosch guide on my blog here -- When in doubt - There is no doubt - Go the safer route. |
153 days ago |
I would think you would want to look into an inlay set with bushings and the smaller bits. There are a ton of guys here that can explain the details. I don’t think it would require a router table to do, but I may be wrong. Most of the inlay work I have seen has been done with templates that you rout through using the bushing as a guide. ~DB -- He said wood...http://hickbyassociation.blogspot.com/ |
153 days ago |
If I’m correct, the holes are 3/8” deep and 3/4” wide….if that’s right, I would use a plunge router with a 3/4” stright bit…..simple -- Francisco Luna, San Francisco Bay Area. |
153 days ago |
If I understand this correctly, like Moai just posted, you want holes 3/8” deep, and 3/4” diameter – use a forstner bit and a drill press. If you don’t have a drill press use a hand-held drill, but first drill through some 3/4” scrap sheet good to use as a jig. Clamp the sheet good on your picture frame and use it to hold your bit in the right spot while you drill. That way you don’t have to worry about slipping and messing up your picture frame. For your depth of 3/8” just take it easy, and you can sneak up on all four holes, of course if you have a drill press just set the stop on it. -- Rand Richards, Wood.Shop@mac.com, wood-shop.org |
153 days ago |
That’s less dangerous than a router, I agree with Rand -- Francisco Luna, San Francisco Bay Area. |
| Forum | Topics |
Woodworking Skill Share
2813 |
3775 |
247 |
896 |
212 |
Woodworking Trade & Swap
593 |
Coffee Lounge
2279 |
LumberJocks.com Site Feedback
507 |
