How would you gang cut these pickets?
Forum topic by JC posted 167 days ago 778 views 0 times favorited 49 replies Add to Favorites Watch
View JC's profile
JC
127 posts in 691 days
167 days ago
Topic tags/keywords: fence picket cut bandsaw circular saw help advice williamsburg
need to cut about 200 pickets… each has a double point at the top (like these: http://www.history.org/publications/books/images/wmsbgglgardens.jpg) – how would you do the valley cut in the center? would you do 5-6 at a time on the bandsaw, line them all up end to end and use a circular saw?
the pickets are 40×6 x 3/4 inches, they will have a double point at the top, like an upside down “W”
appreciate any thoughts!
JC
-- JC - Central PA - www.affyx.com
View Rustic's profile
Rustic
1247 posts in 489 days
167 days ago
you could cut them on a bandsaw. Your best bet is to do what you feel comfortable.
-- There is no such thing as a mistake. Its called a design modification Rick Kruse, Grand Rapids, MI
View ellen35's profile
ellen35
531 posts in 325 days
167 days ago
I would cut a single point on a miter saw, then cut the v groove with either a band saw or saber saw with a jig…you make the jig.
-- Ellen on Cape Cod
View Gene Howe's profile
Gene Howe
333 posts in 321 days
167 days ago
I’d probably cut single pickets from 1X3s and hold two together with the horizontal rails. That appears to be how they were done in the link/picture you provided.
-- Gene
View kerflesss's profile
kerflesss
131 posts in 261 days
167 days ago
I’m with Gene, 1×3’s and do your points on the miter saw.
View JC's profile
JC
167 days ago
Thanks for your replies so far – I keep picturing lining them all up and cutting the valley along the top with a circular saw, then I can get large batches at one, and I can follow up with the miter saw to quickly clip the corners.
Ellen I like the sabersaw/jig idea, might be a good excuse to finally get a good saber :-)
Gene they are single boards, the one on the right in the pic is slightly split which makes it look like two. I want single boards. There are several fences just like this in Colonial Williamsburg, and while they may not be the most practical, I want an authentic look (i.e. it’s what the wife wants!)
View Julian's profile
Julian
688 posts in 418 days
167 days ago
I’d just use a jigsaw and be done with it. A decent jigsaw like a bosch or dewalt with a good blade will cut those very easily.
-- Julian, Park Forest, IL
2376 posts in 234 days
167 days ago
yes to the above ,
or you could make a jig for the router and use a spiral cutter and bushing to follow it,
any way you decide , it is patience and repetition .
View lew's profile
lew
4481 posts in 648 days
167 days ago
Definitely the jig saw.
Why?- every project requires a new tool purchase. This is Woodworkers Unwritten Rule #2!
It would probably be the fastest method, also
View bentlyj's profile
bentlyj
783 posts in 363 days
167 days ago
I would clamp about 25 of them together and run them through my table saw with the blade set at a 45.
View JC's profile
JC
167 days ago
Thanks again – keep ‘em coming!
I’m putting my money where my mouth is on this question – offering a ONE DOLLAR reward on tweetbrain! https://tweetbrain.com/answers/to/218340—so post your answers there too please!
View HokieMojo's profile
HokieMojo
1140 posts in 621 days
167 days ago
why not tilt your tablesaw blade to 45 degrees and clamp a few of these boards (however many you can comforatbly support) and slide them accross the blad with a mitreing jig. Flip and repeat. Then you’ve got a whole bunch done quickly and in an easy to repeat fashion? not sure if you have a crosscut sled or tablesaw capable of handling the length of the stock though.
HokieMojo
167 days ago
oops, bently beat me to it
View stefang's profile
stefang
1644 posts in 227 days
167 days ago
I like a tablesaw solution best providing you can stand them vertical. I would clamp a bunch together. Two of the angles are the same from each edge. You can register the first edge against a spacer when you do the first cut, then remove the spacer and run it through again registering the same edge to cut the 2nd angled in the same direction. Then register the other edge again with the spacer inserted and do the same procedure again. Of course the blade will be set at 45 degrees.
Hope this is a little clearer than mud. Don’t hesitate to ask for clarification if your interested in this method. This is the same solution as bently but with the addition of the spacer.
-- Mike, American in Norway
ellen35
167 days ago
Can you really stand a 40” picket vertically on a table saw…and do it safely??
I’m curious!
Ellen
HokieMojo
167 days ago
i assume when people say vertically, they mean:
not on its face, but up on its edge
I could be wrong, but thats what I was trying to suggest.
stefang
167 days ago
Don’t see why not Ellen. A bunch clamped together should be plenty stable. The pickets would have their top edge on the table with the width of the picket 90 degrees to the fence. I would make some trial cuts first to ensure accuracy, but once set up it should go great. you might want a scrap piece on the back to prevent tear out on the last piece.
View Joe Lyddon's profile
Joe Lyddon
481 posts in 945 days
167 days ago
1×3 method…
TopamaxSurvivor
3014 posts in 569 days
167 days ago
I’d do it with my circular saw.
View Kindlingmaker's profile
Kindlingmaker
1470 posts in 419 days
167 days ago
You know if you do the cutting outside and as people walk past you might be able to get them to do it because its soooo much fun and maybe even get a frog, kite and broken jack knife…
All kidding aside, The clamping many together and using your table saw would be the quickest if you are safe. All clamped up your might be able to do 25 or more at once… Be safe though.
TopamaxSurvivor
167 days ago
You could line up a lot more than 25 and do it with a circular saw a lot safer than holding them up above a table saw IMO.
View SCOTSMAN's profile
SCOTSMAN
2238 posts in 478 days
167 days ago
I’d do them one at a time I think thats the only way to get good or perfect results possibly with a Handsaw boring answer sorry but how big can one fence be ? So it might take a while how long does the fence need to last? If you get inconsistant results it will look dreadful . When you have so many side by side any small flaw will be instantly recognisable .Alistair
bentlyj
167 days ago
After further review:
Circular saw or table saw, neither will work. Blade would have to cut 3” high/deep at a 45 deg. angle.
You would have to have a 12” saw blade.
I’ll see if I can think of something else.
Joe Lyddon
167 days ago
Make a little jig for the angle cut, use the band saw fence, & cut, flip, & cut on a band saw… (all 1×3’s)
then glue’em together…
bentlyj
167 days ago
After further re-review….....duh (should have looked at your picture) I had steeper cuts in mind.
It looks like the cut only needs to be 1 1/2” deep. Therefore, I would go back to using the table saw if it were me, I’m comfortable with that. But Topamax has a good point about being able to clamp more together and using the circular saw.
TopamaxSurvivor
167 days ago
If the cuts were to be at a 45, they would only be about 2” deep. The hypotenuse is slightly less than 3”. Even so, a 7” circular saw will not cut any near that. a 10” Table saw should come close.
TopamaxSurvivor
167 days ago
Rethinkning this, I think I’d set up a jig on the band saw. Like it has been said, more precision and if they are off, it will be very distracting, especially 2 on the same picket.
View mtnwild's profile
mtnwild
2013 posts in 420 days
167 days ago
How about a jig for a jigsaw, and slam them in the field while you put them up. Less handling and it should not take too long to cut each board as you go down the line.
bentlyj
167 days ago
2 1/8” would be the length of the cut. Depth would still be 1 1/2”
View John Ormsby's profile
John Ormsby
503 posts in 630 days
167 days ago
make a jig /guide for the bandsaw and gang clamp a bunch at a time. You will be done in no time.
-- Oldworld, Fair Oaks, Ca
View kolwdwrkr's profile
kolwdwrkr
2248 posts in 483 days
167 days ago
Are we sure that the boards in the picture are actually 1 board with a “V” cut into it? The one on the right looks like it is seperating as if it were 2 boards.
If not you can set up your miter gauge on the table saw (a slider is prefered that can have a stop) with a sacrificial fence so you can clamp a stop at your length. The boards would be layed up on the saw on edge (length wise horizontal, NOT vertical) and the blade would be tilted to a 45 degree and raised as high as needed to cut to center ~ 2 1/8. You should be able to run the piece through, back up, flip the piece and then run it through again.
TopamaxSurvivor
167 days ago
I was just thinkning they should be be a compound miter cut to cause water to drain out of the “V”. If moisture collects it will cause rot.
View Broda's profile
Broda
235 posts in 412 days
166 days ago
TopamaxSurvivor has a good point about the compound mitre cuts.
I personally would just get two “normal” one pointed pickets and maybe biscuit join them together
-- BRODY. NSW AUSTRALIA -arguments with turnings are rarely productive-
Craftsman on the lake
812 posts in 330 days
166 days ago
I’d build a long rectangular frame with 2×4’s maybe 4-5 feet long, slide a bunch of them vertically into the frame, put a wedge in the end of the frame to bind them in. then I’d use my circular saw, with my edge guide against the outside of the frame, and the blade at a 45 to cut all angles. You’d be able to do dozens of them at a time.
-- The smell of wood, coffee in the cup, the wife let's me do my thing, the lake is peaceful. http://web.me.com/deceiver6/Deceiver/Craftsman_on_the_lake/Craftsman_on_the_lake.html
View JC's profile
JC
166 days ago
Wow lots of great ideas thanks!
Some thoughts so far…
gang cutting on a table saw would be great, but holding the boards perpendicular to the saw table seems unsafe
BentlyJ’s idea to cut them horizontally on the table saw might work (see pics)
picket math
pickets on saw
1×3’s are not an option for my project but I appreciate the suggestions
to cut them on the bandsaw would require a jig but my bandsaw table might be too small
jigsaw might be very time consuming, and mine is a hunk-o-junk
I think tablesaw method and circular saw method are in the lead right now.
By the way, I’m making these this weekend – what a great group dynamic to bring all these minds together on my little issue – thanks all!
Keep ‘em comin!
bentlyj
166 days ago
That was kolwdwrkr’s idea to lay them horizontal but I don’t think your blade will make it to 3” high.
Your pickets are only 40” high. I really think they would be stable enough to push through the table saw. Clamp about 25 of them together and stand them up and see what you think. If your not comfortable ,
DON’T do it that way.
I have a 16” radial arm saw that would be a pc of cake to cut them horizontally.
View CutNRun's profile
CutNRun
122 posts in 739 days
166 days ago
If one is available, I think a radial arm saw may be the easiest and perhaps safest way to cut multiple slats at a time.
My “sketch-up” program involve graphite.
-- CutNRun - So much wood, so many trails, so little time
Joe Lyddon
166 days ago
... use a band saw & get it over with…
... stacked or not stacked… any way you want to do it…
TopamaxSurvivor
166 days ago
You can make your band saw table bigger when you build the jig on a piece of plywood.
kolwdwrkr
166 days ago
You’re not setting the blade to more then 2 1/8” at a 45 degree if you do it my way. When I get back today I am going to make a small video of what I am actually talking about. I’m a happy helperton. Who knows, I may actually make myself out to be an idiot and learn something new in the process. LOL.
25793 posts in 1293 days
166 days ago
I go the table saw way with the slats on their side. two saw setups, and 4 cuts, flipping the slate after the first cut. A nice high fence on your miter gauge of sliding table would keep them stable to run through the blade. I would also suggest a bandsaw but a 40” slat with most of it off the table could be unstable in my mind.
View Skarp's profile
Skarp
176 posts in 219 days
166 days ago
Cordless power beaver.
-- Ooo, er.
kolwdwrkr
165 days ago
I was wrong and accept my status as an idiot. LOL. I drew it on paper while sitting here the other day and didn’t do my figuring right. The blade would have to be raised up more then 3” (more like 4 1/4) so there will be no video to show me being a jack ass. Standing the boards on end would be about the only way to cut them on the table saw. You could clamp quite a few of them together and run them along the fence. You could make a tall “tenoning” jig that could be built to slide along your fence. You could clamp your slats to that and just push the entire setup to make the cut.
A radial arm saw would work wonders. I think if you don’t want to set up the table saw and you don’t have a RAS then a bandsaw would work. You could also just cut them individually with a jig saw, but time is money.
stefang
162 days ago
The tablesaw method is best because you can do it with only one set-up. This will greatly reduce the chance of error and give better more consistent results. I’m sure there are plenty of ways to do this, but why make it complicated? If you are worried about stability with the pickets standing on end, then you can clamp a guide rail on the other side of the clamped multiples to keep everything well aligned.
View JC's profile
JC
160 days ago
Well I went with the table saw horizontal method but the boards were too heavy and wet to gang cut – had to make them one a t a time (only did 18 for the first part of the fence, a small hide-a-fence for the trashcans, the rest of the fence might just be single points)
Turns out my 10” saw all the way up and at 45 degrees is exactly 2.5” above the table, so 5” boards worked perfectly.
Pic one is before and after
two is ripping 3/8” off each side of a 5/4×6 x 10 to remove the roundover and size them down to 5”
three is the first valley cut
four is the hide-a-fence
Thanks again everyone for your suggestions!
Joe Lyddon
160 days ago
Your Valley Cut doesn’t make sense to me…
Your finished fence, to me, does not even use the results of your Valley cut… A 45* Horiz. cut?! Not Vertical?
A pic of cutting the Peaks would be nice… did you cut 1 at a time, etc.?
kolwdwrkr
160 days ago
When in doubt cut an inch off! LOL. Good solution. I knew my method was a good idea ;^)
View Paul 's profile
Paul
118 posts in 482 days
160 days ago
I was going to suggest a chain saw, maybe you were right to go the way you did.
-- Paul, La Center, Washington
View JC's profile
JC
160 days ago
Joe, it’s hard to tell from the crappy pic I took, but pic 3 shows a single board on it edge… maybe “valley cut” is the wrong term…. pic one shows the results.
Thanks KOL!
Paul, a chainsaw is never the wrong answer! :-)
stefang
160 days ago
well, I guess now we will never know how well all the untried methods would have worked. Maybe that’s for the best.
