Heavy-Duty Mixer Lift for Thickness Planer
Forum topic by bak2bak posted 03-11-2015 03:27 PM 1421 views 0 times favorited 1 reply Add to Favorites Watch
View bak2bak's profile
bak2bak
2 posts in 1141 days
03-11-2015 03:27 PM
Topic tags/keywords: question trick tip resource planer milling sanding sander
I have a very small shop (think somewhere between a 1 and 2 car garage) so I am always looking to save space. Recently I was searching online and found this Kitchen Aid mixer lift and thought that would be great to get a few of these to mount my thickness planer!
and drum sander under my bench! the only problem is that it has a maximum load of 60 lbs. My delta thicknesser weighs 72 lbs plus what I am plaining. Do you guys know of something like this that is more heavy duty? I think 200 lbs would do it because any thing that heavy I would use infeed/outfeed rollers. have you guys ever tried this or found something that would work for this? Thanks!
http://assets.rockler.com/media/catalog/product/cache/1/image/720x720/9df78eab33525d08d6e5fb8d27136e95/3/4/34115-06-1000.jpg
1 reply so far
View Rob's profile
Rob
704 posts in 3039 days
#1 posted 03-11-2015 03:56 PM
In case you don’t find a heavy-duty alternative, I’d bet you can make your own heavy-duty lift with a little trial-and-error.
Otherwise a few good alternatives are a flip-top or roll-out planer stand, a heavy-duty pull-out shelf, or some combination of these (e.g., a flip-top roll-out stand).
-- Ask an expert or be the expert - http://woodworking.stackexchange.com
