bowing boards ( sliding barn door )
Forum topic by swimba posted 03-11-2015 03:26 PM 3448 views 0 times favorited 6 replies Add to Favorites Watch
View swimba's profile
swimba
4 posts in 1375 days
03-11-2015 03:26 PM
Topic tags/keywords: bow warp door pine help joining stability
I recently built a sliding barn door for my house with 1” x 8” pine for the front facing frame. It was backed with 3/4” car siding. I ran into the problem of a corner of the door bowing toward the wall and rendering the door inoperable. That was my fault, I didn’t let the wood acclimate. Now I want to re-work the door. Here is my plan, back it with 1/2” ply ( for added stability ) and tack a pine face frame onto that ( simple right? ). My issue with this is that the longer boards ( ~5ft ) when acclimated have slight bows. Is this just something I’m fighting because I’m using pine or is there a fix for this? I’m new to woodworking and typically work on smaller projects so this is throwing me for a loop.
I don’t have a jointer, and even if i did it seems like I would have to loose too much of the stock to completely flatten it out.
My thoughts on fixing ( or stabilizing the bows ) is to rip the boards, joint, and glue them back together with one piece flipped ( so the rings are opposite ) hopefully offsetting the bow. Is this a good fix, or am I just asking for trouble?
Any help is greatly appreciated. I just want the longer boards to be stable so I don’t have to make a 3rd door.
And maybe I’m overthinking it and once the pine is attached to the 1/2” ply that will be enough stability.
View mahdee's profile
mahdee
4024 posts in 1970 days
#1 posted 03-11-2015 04:57 PM
Hard to tell without a picture.
-- earthartandfoods.com
swimba
#2 posted 03-11-2015 05:17 PM
That’s fair, I can take some tonight after the 9-5
View Woodknack's profile (online now)
Woodknack
12431 posts in 2582 days
#3 posted 03-11-2015 05:50 PM
The key to straight doors will be stock selection. Rather than 1×8s, look for 1×12 with the pith in the center, the ends will be quartersawn. Sticker and give the wood some time to acclimate/dry. Rip out the center (pith) and use the ends. Don’t back it with plywood or anything else, that will just cause problems.
Your rip and flip plan is worth trying.
swimba
#4 posted 03-11-2015 06:00 PM
If i did that, would you recomend using 2×12 and running a groove for a center pannel? That is aprx the width I’m looking for.
Woodknack
#5 posted 03-11-2015 07:37 PM
Something like this? Totally doable.
swimba
#6 posted 03-11-2015 08:00 PM
Yeah, but I’m thinking just one cross piece like this:
..except vertical
