Can I use one dado blade?
Forum topic by Jesse posted 03-11-2015 03:26 PM 2201 views 0 times favorited 12 replies Add to Favorites Watch
View Jesse's profile
Jesse
3 posts in 1042 days
03-11-2015 03:26 PM
Topic tags/keywords: dado table saw shaker cabinet doors
I’m getting ready to cut the grooves on all the lumber to build 24 shaker style cabinet doors. I’m using 1/4” oak laminate plywood which measures 0.20”.
After some trial and error I figured out if I use a single outer blade from my Diablo dado set, I get a perfect groove with a flat bottom. If I used two, it was 0.25” and was too loose. I figured this out on a couple scraps and I’m concerned about only using that blade on all the lumber. Will it make that blade prematurely dull with too few teeth?
I tried my 40T Bosch blade I use for everything else by running the board through twice and I got a perfect width, but the bottom isn’t flat and shows a little on the end where you’ll see the tenon.
Any advice would be greatly appreciated!
Thanks!
12 replies so far
View knotscott's profile
knotscott
7817 posts in 3245 days
#1 posted 03-11-2015 03:35 PM
I’d be more concerned about the lack of any over hang on one side of the outside cutter than dulling. The outside cutters of a stacked dado are intended to work in pairs, so that there’s always some overhand of the teeth on each side. Without that, there’s much greater risk of wood rubbing on the body of the blade, and possibly causing kickback.
View SirIrb's profile
SirIrb
1239 posts in 1100 days
#2 posted 03-11-2015 03:37 PM
Since each blade on a stack dado cuts just what its thickness is it will dull at the same rate of normal stack useage.
Jesse
#3 posted 03-11-2015 03:42 PM
That’s a good point! I’ll have to look at that. I’m very new to using a dado set. Very new as in, I’ve only done one project with it!
I might have to see if I can find an FT blade at the local Menards. My current blades are all ATB and leave grooves in the bottom.
Thanks knotscott!
4819 posts in 2362 days
#4 posted 03-11-2015 03:47 PM
All you need is a ripping blade, they cut flat bottoms. If cutting cross grain, it pays to be carfeul trying this.
View Ocelot's profile
Ocelot
1862 posts in 2507 days
#5 posted 03-11-2015 04:11 PM
For narrow grooves I have used a Freud rip blade with a flat tooth profile, along with a precision jig to make multiple passes. I only did that on one project, but it worked OK.
http://lumberjocks.com/projects/92631
My dado set has warnings stamped on it – not to use the outside blades alone.
View bondogaposis's profile
bondogaposis
4523 posts in 2220 days
#6 posted 03-11-2015 04:27 PM
A better set up is to use a ripping blade in two passes, if you flip the board your dado will be perfectly centered as well.
-- Bondo Gaposis
View Rob's profile
Rob
704 posts in 2940 days
#7 posted 03-11-2015 04:27 PM
If you don’t want to drop a lot of money on a new blade, a couple more options are to clean up the bottoms with a router plane or cut the dadoes with your router and a straight bit.
-- Ask an expert or be the expert - http://woodworking.stackexchange.com
Jesse
#8 posted 03-11-2015 06:03 PM
Thanks everyone! After some reading, it looks like a ripping blade is what I need.
I hadn’t noticed warnings about using the outside blades, but I bet it’s there somewhere! Thanks Ocelot!
Bondo, I was flipping them. The secong pass was only taking a sliver off though. Thanks for the info!
Rob, I’d rather buy a new blade because my router is a bit of a turd and I don’t trust it. I’ve done similar grooves with it before and ended up scrapping a few pieces. I have plans to buy a new one and build a better table for it, but just haven’t gotten there yet.
View gfadvm's profile
gfadvm
14940 posts in 2559 days
#9 posted 03-12-2015 12:12 AM
Not all rip blades have a flat tooth design as Knottscott pointed out to me a while back. My 24 tooth Freud Diablo does not.
View HerbC's profile
HerbC
1706 posts in 2728 days
#10 posted 03-12-2015 12:32 AM
If you have to buy a new blade, this one by Kempston is flat toothed and I’ve found it to be excellent. And the price was good.
Good Luck and remember…
Be Careful!
Herb
-- Herb, Florida - Here's why I close most messages with "Be Careful!" http://lumberjocks.com/HerbC/blog/17090
Ocelot
#11 posted 03-12-2015 03:23 PM
Freud LU87R010 24-tooth 10-in thin kerf flat tooth. They claim 0.094” kerf. Mine cuts wider than that.
$37.99 and free ship on Amazon today.
There is also a non-thin-kerf version which might be what you want depending on what you’ll be doing.
Freud LM72R010 with 0.126 kerf is $55.99 on Amazon.
-Paul
View jmartel's profile
jmartel
7615 posts in 2019 days
#12 posted 03-12-2015 03:32 PM
If you’re going to buy a flat top ripping blade, buy a full kerf one. That way you have exact 1/8” cuts. I’d rather have that than 0.094”. I’m never going to use material thinner than 1/8” when putting in a dado, so that works well for me.
If for some reason I needed thinner, I would probably use my router table and a 1/16” bit.
http://www.amazon.com/gp/product/B00004T78V/ref=oh_aui_detailpage_o09_s00?ie=UTF8&psc=1
