pocket hole joinery and wood movement?
« back to Joinery forum
Forum topic by WoodNSawdust posted 03-11-2015 01:09 PM 4669 views 0 times favorited 12 replies Add to Favorites Watch
View WoodNSawdust's profile
WoodNSawdust
1417 posts in 1082 days
03-11-2015 01:09 PM
Topic tags/keywords: workbench wood movement pocket hole question
Is there sufficient play in a pocket hole to allow for seasonal wood movement?
If not, can a pocket hole be elongated by drilling a hole then sliding the jig over a 1/32 inch and re-drilling?
The application:
a 2×4 frame out of “white” wood that will have pocket holes to hold a 2” thick oak top (from an old table) to form my first workbench. Top is 24” x 60” with oak strips that are 2” wide with the grain turned in various directions and then glued together.
Workbench will be located in an unheated / air conditioned shop. Here in Missouri temperatures can range from 100 degrees with 100% humidity in the summer to 0 degrees and no humidity in the winter.
12 replies so far
View Bill White's profile
Bill White
4856 posts in 3866 days
#1 posted 03-11-2015 03:07 PM
I’ve used a bunch of pocket hole applications without any untoward results. Just use the correct screw for the application.
Bill
-- bill@magraphics.us
View jmartel's profile
jmartel
7687 posts in 2056 days
#2 posted 03-11-2015 03:13 PM
You can always drill out the hole a bit larger on the side that gets the head of the screw. Go up another size or two of drill bits and it would allow for movement.
View HornedWoodwork's profile
HornedWoodwork
222 posts in 1120 days
#3 posted 03-11-2015 04:32 PM
Yes you can elongate the holes but I would suggest drilling the pocket hole, then drillilng a pilot hole to locate the hole from the other side and cutting away stock from that side instead. The reason I would do this is it will not affect the screw’s ability to bite down and hold, but it will allow for some travel in the wood.
-- Talent, brilliance, and humility are my virtues.
WoodNSawdust
#4 posted 03-11-2015 05:11 PM
Within reason, is there any danger of making the hole too elongated?
Say the actual wood movement is 1/32 of an inch over a year and I make the hole 1/16 elongated.
116906 posts in 3483 days
#5 posted 03-11-2015 05:27 PM
Depending on your use of pocket screws it may be ok but the most common mistake I see online is when folks use pocket screws to connect wide expanse of wood like table tops I defiantly would not recommend the use of pocket screws. There are a number of ways to connect tops that do allow for wood movement.
This thread shows some examples.
http://lumberjocks.com/topics/62485
View bondogaposis's profile
bondogaposis
4603 posts in 2257 days
#6 posted 03-11-2015 06:08 PM
All joinery methods have to take into account wood movement to be successful. Pocket holes are no different, if you use them where appropriate you will have no problems.
-- Bondo Gaposis
WoodNSawdust
#7 posted 03-11-2015 06:29 PM
@a1Jim: thanks for the link there is some good info there.
Are pocket hole screws strong enough to handle the racking forces involved in fastening a workbench top to the frame when using tools? I would hate to have the screws break off as I was using the workbench.
#8 posted 03-11-2015 06:37 PM
WoodNsawdust
Yes there probably are strong enough not to break, but it will not stop wood movement,so the top will probably crack.
the best solution is to use one of the correct ways to connect the top as outlined in the link I posted.
View hotbyte's profile
hotbyte
991 posts in 2881 days
#9 posted 03-11-2015 06:45 PM
Two thoughts on use of pocket hole screws…
1) Large/wide panels of plywood/MDF type sheet goods that are stable
2) Smaller width solid boards like face frames where expansion/contraction is minimal.
Stick with other attachment methods like a1Jim’s link for wider solid panels/tops with more movement.
View moke's profile
moke
1103 posts in 2682 days
#10 posted 03-13-2015 05:42 PM
+1 with A1Jim….always allow for movement with a table top…...DAMHIKT
Mike
-- Mike
View JAAune's profile
JAAune
1780 posts in 2222 days
#11 posted 03-14-2015 12:20 AM
I don’t trust pocket holes when it comes to wood movement either. I’ll often use them to fasten the center of a table top then pull the sides down with clips inserted into grooves.
View bbasiaga's profile
bbasiaga
1120 posts in 1901 days
#12 posted 03-22-2015 09:05 PM
you can also run some cross members between your front and back of your frame, underneath the table. Drill some holes that are oversized for the screws you are going to use, but still small enough that the head will catch. Drill the holes close to the middle so the table top an expand out in both directions if needed. The wiggle room in the screw hole should give it the space. Same idea as the buttons.
Your cross members can be pocket holed in.
I’ve seen this a bunch of smaller tables. Would imagine the idea scales to larger ones.
-Brian
