Mirka CEROS: Can I put 6" Pad on 5" Model?
Forum topic by GregH posted 03-11-2015 12:49 AM 1444 views 0 times favorited 10 replies Add to Favorites Watch
View GregH's profile
GregH
36 posts in 1106 days
03-11-2015 12:49 AM
Topic tags/keywords: mirka ceros sander
The title says it all:
I’m going to buy a Mirka CEROS and will be sanding everything from interior doors to cabinets and small boxes. If I buy the 5” (CEROS 550CV) can I use a 6” pad and paper on it when I’m sanding larger pieces?
Thanks,
Greg
-- I was in the market for a new obsession and wound up here.
10 replies so far
View bobkberg's profile
bobkberg
439 posts in 2976 days
#1 posted 03-11-2015 01:12 AM
Hi Greg,
You can, but you would be throwing money (and sandpaper) away. In addition, you may damage some of your work.
The 5” disks are already slightly larger than the backing pad. Trying to sand something with no backing pad behind it is a waste of effort, and if the edge rips, you could have a flailing piece of sandpaper that could damage something.
I just did a quick look and the 5” and 6” models are essentially the same price. I’d suggest looking at buying a replacement pad if you can get both the 5” and 6” to mount on the same motor unit.
-- Bob www.singularengineering.com - A sideline, not how I earn a living
GregH
#2 posted 03-11-2015 02:08 AM
Hey Bob,
I misspoke in my post. I meant to say can I mount a 6” Backing Pad (i.e., Mirka #8295291511 Backing Pad 150mm 5/16th” Grip 15H Medium) onto the 5” CEROS?
I’m hoping it would work because then I could get double-duty out of the one motor body.
bobkberg
#3 posted 03-11-2015 03:39 AM
I did a quick Google search and found that the price is almost the same. I’d recommend that you look at the replacement pads and see if they will mount on the same way.
GregH
#4 posted 03-12-2015 02:14 AM
Looking at the parts schematic for the CEROS it appears the backing pads could be interchangeable. Even the shrouds look to be the same except the 6” is one inch larger than the 5”.
I would like to hear from an owner who has tried it out, though.
View shipwright's profile
shipwright
7894 posts in 2701 days
#5 posted 03-12-2015 02:18 AM
It would be interesting to find out. Have you asked a dealer?
I bought the 5” because it will go in smaller places and can still do bigger jobs. I’m not sure a 6” would be enough faster on bigger jobs to justify two sets of discs in inventory though.
GregH
#6 posted 03-12-2015 02:42 AM
That was my thinking in going with the 5” CEROS. But I have 21 doors I’ll be painting this spring (wife changing interior colors from stained to white paint) and thought the 6” could make it go a bit faster.
I’ll give Mirka a call and see if it will work. Good point about the inventory, Paul.
GregH
#7 posted 03-13-2015 01:41 AM
All three CEROS models (3”, 5”, 6”) use the same motor and the same 5/16” stud mount. They also use the same AC/DC converter power source.
So no problem with using a 6” backing pad on the 5” CEROS.
shipwright
#8 posted 03-13-2015 04:13 AM
Good to know but the inventory cost will keep me in 5” I think.
GregH
#9 posted 03-13-2015 01:39 PM
Agreed, buying another backing pad at $41+ and the additional 6” sanding discs would buy a lot of 5” paper. I guess I’ll just cover the extra 1” diameter with a little extra time!
View CharlesNeil's profile (online now)
CharlesNeil
2210 posts in 3773 days
#10 posted 03-13-2015 01:49 PM
I have the ceros and the deros , bought 6” , but switch to 5” when needed ..No issue
