How would you make a lot of .160 kerf slots in from edges on 1/8" ply?
Forum topic by Bob in Salem posted 06-06-2009 07:55 AM 1256 views 0 times favorited 5 replies Add to Favorites Watch
View Bob in Salem's profile
Bob in Salem
6 posts in 3450 days
06-06-2009 07:55 AM
I need to make a lot of these slots and the 1/8” ply pieces are as small as 2” x 2” with 4 slots. I’ve had to make two passes with my my 5/32 router bit. I asked the local Carbide Sharpening Co. if they could grind down a 3/8 bit and they said the bit wouldn’t perform well as the chips wouldn’t escape properly. They’d have to grind additional relief and don’t have the equipment to do that.
I could do it with a table saw blade but I can’t find anything with a kerf that big. I suppose I could grind down a 1/4” dado blade to .160. Anybody ever do this? Any foreseeable problems?
I’m also considering setting up a gang slot cutter with a 1/2” shaft maybe 2’ long running through some pillow blocks. I could space out cutters at 2” intervals and cut lots of slots at a time. However, slot cutters are designed to run at 11000 rpm and I’m not sure if the bearings would handle those speeds.
Any ideas?
Bob in Salem
-- - - Ever notice that all tape measures are left handed? - -
5 replies so far
View knotscott's profile
knotscott
8140 posts in 3549 days
#1 posted 06-06-2009 11:08 AM
Can you gang two ultra thin kerf blades and use shims to fine tune the slot? There are some blades in the .079” range from Tenryu and others.
View miles125's profile
miles125
2180 posts in 4179 days
#2 posted 06-06-2009 11:28 AM
One of those Craftsmen table saw moulding heads would work if you have one. Easy to grind two blanks to just the size you need. Make a zero clearance plate when you get it right and you’re in business.
-- "The way to make a small fortune in woodworking- start with a large one"
Dick, & Barb Cain
8693 posts in 4473 days
#3 posted 06-06-2009 12:47 PM
I’m not quite sure what you mean, but maybe something like this stackable slot cutter would work.
you may be able to buy one with all 5/32” cutters.
knotscott
#4 posted 06-06-2009 01:37 PM
Systimatic makes some 12” blades that have a 0.161” kerf…$57. You might be able to bush the 1” bore down to 5/8” and fit it on your saw, but it’ll depend on the saw…
37222 12HR24-109
117272 posts in 3750 days
#5 posted 06-06-2009 04:52 PM
Looks the slot cutting bits will do the job
