How to keep DC canisters clean???
Forum topic by Drew posted 03-10-2015 02:16 PM 931 views 0 times favorited 9 replies Add to Favorites Watch
View Drew's profile
Drew
350 posts in 3096 days
03-10-2015 02:16 PM
I am using a Grizzly G0562zp (3hp twin canister DC). When the filters are very clean this thing works great! Takes care of my entire shop pretty good, including a 37” dual drum sander.
The problem is the filters clog up with dust to fast and I lose way to much suction. For everyday use I can get away with turning the handles to clean them out…. a little bit at least. I really have to take them off to clean them out adequately, and that makes a huge mess.
My big issue is the drum sander. If I clean the filters out this machine works great with my drum sander… for about 30-45 minutes. Then after that I have to spin the handles about every 15-20 minutes. And even then it is only running about 60-70%. I can’t keep doing this!
Another thing I have found is most of the dust you knock out of the filters just sits on top of the baffle…. Then back into the filters as soon as I turn it back on!
Does anyone have a solution?
I don’t think I want a pre-separator. That would be big and expensive with 6” pipe!
Has anyone used an internal baffle/separator to keep dust in the bags on a set up like this?
-- TruCraftFurniture.com
9 replies so far
View WoodNSawdust's profile
WoodNSawdust
1417 posts in 1173 days
#1 posted 03-10-2015 02:24 PM
add a cyclone pre-separator before the impeller on the Grizzly. Depending on where you read the specs the cyclone will remove somewhere between 90 and 99% of the dust before it reaches your filters. You should expect a reduction on CFM.
View Drew's profile
Drew
#2 posted 03-10-2015 02:32 PM
Yea…. I am hoping to avoid this. I would want everything hard piped. That would take up some space and I have to think all the 6” fittings would get expensive.
Have you seen anyone do this with 6”?
View johnstoneb's profile
johnstoneb
2914 posts in 2169 days
#3 posted 03-10-2015 02:50 PM
+1 WoodNSawdust The only way to keep sanding dust and chips out of the filters is a preseparator. So choose your poison.
-- Bruce, Boise, ID
View BoardSMITH's profile
BoardSMITH
121 posts in 2260 days
#4 posted 03-10-2015 03:01 PM
Had somewhat the same problem. The disc sander created so much fine dust it bypassed the cyclone and then clogged the filter which was a monumental mess to clean. Before I dumped the double drum sander in favor of a wide belt sander, I contracted with a company to build a custom bag house. When it was ready I trashed the inefficient and poorly designed HEPA filter and installed the bag house. Now all I have to do is knock out the dust from the bags which falls down to a collection bag then empty the collection bag. Much easier to clean, less mess than cleaning out the filter and more efficient than the old filter. Also clogs less often.
-- David www.TheBoardSMITH.com
4984 posts in 2490 days
#5 posted 03-10-2015 03:08 PM
I have a cyclone, and the DS was so hard on the filter I installed a gauge to tell me when to clean it. When I was using it a lot, I would have to clean the filter twice for each 55 gallon barrel of chips. After 6 years, the filter got so clogged i couldn’t clean it any more (as evidenced by my gauge) and I replaced it. BTW, my cyclone does remove 99% (actually, 98.4% by volume) of the total debris by volume, and I still had problems. The 1.6% in the filter was all the finest dust. Even so I think a pre seperator would alt least help with the problem, and a Thein wouldn’t be too hard to build.
View Drew's profile
Drew
#6 posted 03-11-2015 04:22 PM
Maybe I will just have to get a super dust deputy.
Anyone here use one? And if so is worth the extra money for the xl with a 3hp unit?
View timbertailor's profile
timbertailor
1594 posts in 1421 days
#7 posted 03-11-2015 04:31 PM
You need a filter with adequate flow and low particle removal like what Wynn Environmental Filters provide.
Here is my solution. The separator is in the trash can. I used sheet aluminum to make the transitions and save on costly piping. Hope I could help.
View Rob's profile
Rob
704 posts in 3067 days
#8 posted 03-11-2015 04:52 PM
I don t think I want a pre-separator. That would be big and expensive with 6” pipe!
I’m not sure I understand this comment. I haven’t seen any cyclone/separator setup that requires more than a couple feet of extra pipe or hose to hook up.
-- Ask an expert or be the expert - http://woodworking.stackexchange.com
View Drew's profile
Drew
#9 posted 03-11-2015 05:31 PM
I would want it hard piped. 6” couplers add up fast. Was looking for a less expensive solution.
As for size… My twin canister DC already takes up a lot of space in the middle of my shop. Don’t really have room for a big can in that area.
I m not sure I understand this comment. I haven t seen any cyclone/separator setup that requires more than a couple feet of extra pipe or hose to hook up.
- Rob
