| Forum topic by Thomas Keefe | posted 1448 days ago | 624 views | 0 times favorited | 7 replies | ![]() |
1448 days ago |
Topic tags/keywords: question router joining I have a plunge router I use to cut mortises. I have noticed that there is some “wobble” in the plunge mechanism so that sometimes the bit does not go straight down. If I push a little more on one handle than the other, the bit will veer off the vertical a bit. Thus, my mortise might not end up exactly where I want it. It is generally not off by more than 1/16-1/32”. My question is: Is this common for plunge routers or are some very precise, i.e., the bit always goes straight down. Is there some type of adjustment to the router that can be made to reduce this problem? Thanks. Tom |
7 replies so far
#1 posted 1448 days ago |
I have had the same problem with my Freuds so I tried a Bosch and found it was much smoother with the plunge. -- Never board, always knotty, lots of growth rings |
#2 posted 1448 days ago |
I have seen this on my Craftsman. I slid off the base, and springs. Cleaned them upThoroughly. then, i was carefull not to get oil on the post that sets the height. I also had to be careful of a small brass piece that helps hold the height properly. If after cleaning, check that part. You may have to slide it back in place. Mine works a lot better now. You may check that the post is not loose on the base. Or if it can be, but that would allow the router to move poorly. -- Saved, and so grateful, consider who Created it ALL!!! |
#3 posted 1448 days ago |
I have a porter cable 2 1/4 hp plunge router and find it to be very accurate. I recently cut 84 mortises for a mission table I am building for my wife and am very happy with the results. -- Every step of any project should be considered your masterpiece if you want the finished product to reflect the quality of your work. http://www.FineArtBoxes.com |
#4 posted 1448 days ago |
I have not found that with my porter cables. They seem dead on. -- Life is to short to own an ugly boat. |
#5 posted 1448 days ago |
What kind of router do you have Tom? I haven’t had this problem with any of mine. -- I didn't go to college, I was too busy learning stuff - Ted Nugent |
#6 posted 1447 days ago |
Thanks everyone for the advice. I took olddutchman’s advice and took the base off and cleaned out the Hi Tomakazi. The router is a Pit Bull. It cost about $100 at Ace Hardware. While I know it is not great quality, Tom |
#7 posted 1447 days ago |
Hey tom -- W James Brokenbourgh Custom furniture maker http://artisticwoodstudio.com/ |
| Forum | Topics |
Woodworking Skill Share
8797 |
Woodturning
224 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
82 |
Finishing
1535 |
3553 |
15803 |
Hand Tools
2038 |
Jigs & Fixtures
496 |
Wood & Lumber
2844 |
809 |
Focus on the Workspace
903 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6163 |
