Tapping leveler holes in phenolic resin for a zero clearance insert
Forum topic by steveinaz posted 03-10-2015 02:48 AM 1581 views 0 times favorited 10 replies Add to Favorites Watch
View steveinaz's profile
steveinaz
46 posts in 1412 days
03-10-2015 02:48 AM
I made a insert for my table saw from phenolic resin. The leveler holes I tapped allow the set screw to run freely, there is no resistance and thus no holding a set point. I used a regular 10-24 tap and a 1/2” set screw. What should I have done so the set screw does not run freely?
-- Steve in AZ
10 replies so far
View Aj2's profile
Aj2
1950 posts in 2035 days
#1 posted 03-10-2015 02:56 AM
How about a drop of glue in each hole.With the set screw out let it set over night.Then run the screw back in for a interference fit.If it doesn’t work can always clean it up with the tap..Aj
-- Aj
View TheFridge's profile
TheFridge
10816 posts in 1723 days
#2 posted 03-10-2015 03:21 AM
Loctite maybe? Don’t know if it’s compatable with plastic but that’s my first thougt.
View Shadowrider's profile
Shadowrider
183 posts in 1447 days
#3 posted 03-10-2015 03:31 AM
I used to use stuff called “vibra tight” on carb screws of race bikes. No matter what you did with the springs the screws would always work their way out and screw the mixture up. It hardened to a tough wax and worked well.
Silicone caulking might work too.
Edit: It was called Vibra-tite. This is it…. http://www.amazon.com/Vibra-TITE-VC-3-Threadmate/dp/B008D6GHY6/ref=pd_sbs_auto_8?ie=UTF8&refRID=1Y3JR86B97MJZ0KXQ2DY#product-description-iframe
View ChefHDAN's profile
ChefHDAN
1230 posts in 3087 days
#4 posted 03-10-2015 11:56 AM
Blue loctite will do the trick, have had same issue
5236 posts in 2731 days
#5 posted 03-10-2015 12:02 PM
Can you put threaded inserts into phenolic? I think that may have been what I would have tried.
View MrRon's profile (online now)
MrRon
5264 posts in 3481 days
#6 posted 03-10-2015 06:40 PM
What you should have done was to use a tap drill one size smaller than listed; a #27 drill instead of the #26. I do this with my inserts and the screws are tight.
steveinaz
#7 posted 03-11-2015 04:11 AM
MrRon – Thank you, To clarify, are you using a tap to cut the threads or are you using the set screw to cut the threads? I tried using the set screw to cut the last couple of threads and I stripped the head. The phenolic resin sheet was too tough for the stainless steel set screw.
-- Steve in AZ
View waho6o9's profile (online now)
waho6o9
8539 posts in 2814 days
#8 posted 03-11-2015 05:15 AM
steveinaz
#9 posted 03-11-2015 02:09 PM
Thanks everybody, I used blue Loctite and it seems to be working, time will tell.
-- Steve in AZ
MrRon
#10 posted 03-11-2015 03:13 PM
- steveinaz
TAP. I use 8-32 set screws on my inserts. Since you have already made the insert and drilled the holes, all you can do now is use a thread locker.
