Question about TS Adjustment
Forum topic by Tim Marko posted 171 days ago 256 views 0 times favorited 11 replies Add to Favorites Watch
View Tim Marko's profile
Tim Marko
41 posts in 682 days
171 days ago
Topic tags/keywords: tablesaw question
I just finished tuning up my table saw and I’ve found a problem that I can’t figure out and was hoping someone hear had an answer.
The board I started with was jointed on one edge so i had a true starting point. I set the fence at 1.75”.
The leading end of the board was at 1.75” confirmed with a caliper. The tail end was 1.75”. The middle of the board was 1/64 wider. My first instinct was operater error so I rechecked three more times. Each time the results were the same. The board was about 16” long.
The answer may be obvious, but I can’t seem to see what could be causing this.
Any ideas?
-- Tim, trying to come up with something cool to say here!
TopamaxSurvivor
3014 posts in 569 days
171 days ago
Is your fence true and aligned it’s full length?
Tim Marko
171 days ago
Top,
I just checked to be sure and yes it is true and the alignment was just done. I also checked to see if I’m getting any deflection, and don’t see or measure any.
View knotscott's profile
knotscott
522 posts in 269 days
171 days ago
It’s possible to get some deviation even with a jointer. Did you check the reference edge for flatness before cutting?
View RedShirt013's profile
RedShirt013
116 posts in 555 days
171 days ago
Try using a full kerf blade if you’re not already, or use some stiffeners to flank the blade
-- Ed
Tim Marko
171 days ago
scott, I did check the reference edge and it was true.
red, I do use a stiffener, but it is on a thin kerf freud blade if that helps.
View treeman's profile
treeman
149 posts in 343 days
171 days ago
Is it possible that you are over feeding and deflecting the blade?
Try a cut at a more moderate speed and see if that helps.
View woodman71's profile
woodman71
59 posts in 217 days
170 days ago
Hello Tim If I can give my two cents I will say check to see if your blade is square to the table. It not hard to do you might know how to this but I will tell you anyway. Start by measuring for trailing edge of blade to your miter slots using the same tooth turn the blade to make it to leading edge they should measure the same if not check owners manual to adjust. Hope this help
View olddutchman's profile
olddutchman
74 posts in 828 days
170 days ago
Have you checked the shaft? If there might be a slight movement, that could cause problems, Also, check the miter slot with the miter guage It could happen if there is play in a part of the movement.
-- Saved, and so grateful, consider who Created it ALL!!!
View matt garcia's profile
matt garcia
716 posts in 565 days
170 days ago
Yeah, I think your reference edge wasn’t straight.
-- Matt, Houston Texas
View TheCaver's profile
TheCaver
292 posts in 733 days
170 days ago
ditto on the ref edge….sounds like your jointer outfeed table is off or technique on the jointer.
I’d verify that the jointed edge and fence is truly straight. If your fence is straight and you have a straight ref edge, there is not much that can go wrong. Even blade deflection could not account for both ends being off….However, a bow shaped ref edge that is held tightly against the fence can cause this problem exactly….
Try a featherboard just ahead of the blade rather than a ton of pressure against the fence at both ends….?
Also, are you POSITIVE that the width is off? Now you are introducing a second possible problem into the mix.
You can also do this: create 2 reference edges and cut the other side of both…..line them up together and see what you get.
Does your blade nip the trailing edge of the board? Do you get burning on any portion of your cuts?
Even if the blade is heeling, I don’t think that will cause the issue, since the part that does the cutting is not moving relative to the width. IE, a router bit….its not parallel to a slot, yet it cuts straight lines, but only if your fence and ref edge is straight. Your problem is bound to be there…..or in your measuring technique. DAMHIKT….I’ve corrected all kinds of problems that did not exist :) Or that I created myself :)
JC
-- Somewhere, something incredible is waiting to be known. -Carl Sagan
Tim Marko
169 days ago
I finally got a chance to get back in the shop and try to solve the problem. I got the problem solved, but unfortunatly, everybody here was partially correct. Fortunatly, you were all here to be correct.
What I found as I went back through the entire process, were a number of things that were just slightly off that just kept compounding as I went through the process. I reset the jointer, retuned the TS realigned the fence and tried again and it works just fine.
JC, I found that a big part of the problem was my use of the caliper. I have a digital caliper that will measure in fractions and mils as well as meteric. The difference in the board when measured in mils was only a few thousandths (still not good but not as bad as I thought). When measured in 64ths, it was just enough to read as an extra 64th off.
Thanks for everyones help. It just goes to show you how tiny problems compound each step of the way.
