I am looking to get Grizzly 37 inch drum sander
Forum topic by ryan86 posted 03-10-2015 02:46 AM 1312 views 0 times favorited 11 replies Add to Favorites Watch
View ryan86's profile
ryan86
14 posts in 1173 days
03-10-2015 02:46 AM
Topic tags/keywords: drum sander grizzly 37 drum sander 18 open end drum sander sander sanding finishing question
I run a small woodshop that makes custom tables and cutting boards. When I started out I did not have to much money so I bought the grizzly 18” inch open end drum sander. Even after a brand new motor it is just not cutting it. I’m looking to get a grizzly 37” drum sander. Should I get this product or get out while I still can?
11 replies so far
View Mark Kornell's profile
Mark Kornell
1169 posts in 2530 days
#1 posted 03-10-2015 05:42 AM
I have the G0449. No regrets, it is a decent machine. As with any drum sander, though, the max you will be able to take on a single pass is about .01”. Maybe .005” if you are using the full width.
For any machine that size, you will need good dust collection…
-- Mark Kornell, Kornell Wood Design
ryan86
#2 posted 03-10-2015 06:34 PM
Do you think since it is only a single phase affects what it can do? If you had to do it again would you get a 3 phase or a single phase.
View Drew's profile
Drew
350 posts in 3099 days
#3 posted 03-10-2015 07:33 PM
I feel this is the best drum sander on the market.
Phase (15hp vs 10hp) doesn’t effect it as much as it being a drum sander. There is only so much they can do.
I couldn’t afford a wide belt sander, large compressor and 5hp+ dust collection so I opted for this.
Keep in mind- I have run well over a thousand…. maybe 2 thousand glue ups through a dual drum 43”, 40+hp scmi wide belt sander (not to mention thousands of BF)- and I am happy with my 449
.01 is pretty much a max pass. Most are more like .005 Sometimes you can only go 1/4 turn (0.0025), but the scmi at 40hp was only .025 max.
You will burn up paper!
If you can’t afford a wide belt sander than this is your best option. Or try to save more money for a wide belt…. which might be easier to do if you buy a 449 first
-- TruCraftFurniture.com
View Pezking7p's profile
Pezking7p
3217 posts in 1651 days
#4 posted 03-10-2015 07:37 PM
Just saw a very wide (51”?) grizzly sander in the greensboro NC area on Craigslist for $2500 I believe. Almost new and used only by a company. I thought it looked very cheap but I have no need for a 30hp sander.
I have no affiliation with the sander or CL, just haopened to see it posted.
-- -Dan
View ,'s profile
2387 posts in 3546 days
#5 posted 03-10-2015 07:42 PM
We have that sander and it is very nice. Mine is single phase and no regrets.
View copcarcollector's profile
copcarcollector
256 posts in 2116 days
#6 posted 03-10-2015 08:04 PM
Another option is the Wood Master 38” drum sander, currently $3599.00
www.woodmastertools.com
Oh, I see the Grizzly is a dual drum sander, the WM single drum. Anyhow, might be worth a look—
Mark Kornell
#7 posted 03-10-2015 08:21 PM
Ryan,
As Drew mentionined, single phase vs three phase is a non-issue. It is about how much heat you can put into the paper before it breaks. The 449 has more than enough motor to make thick enough passes that will cause heavy cloth paper to fail spectacularly.
If you already had three phase service to where you want the sander located, I can see where the three phase model would be a good choice. But not because you need extra HP.
And, BTW, one turn of the crank is about .02”, not .01 as Drew implies. A quarter turn is .005”.
View AlaskaGuy's profile (online now)
AlaskaGuy
4138 posts in 2308 days
#8 posted 03-10-2015 08:30 PM
+1
ryan86
#9 posted 03-11-2015 12:22 AM
Thank ya’ll for all the replies. Definitely strengthened my decision.
What size dust collection system should I use to properly extract the dust. What size do ya’ll have?
Mark Kornell
#10 posted 03-11-2015 04:25 AM
Grizzly recommends a minimum of 1600 cfm. That puts you into something in the 5 HP range. Personally, I have a ClearVue CVMAX and use 8” ducting
View DrDirt's profile
DrDirt
4424 posts in 3741 days
#11 posted 03-11-2015 07:38 PM
At the pricing, I would get the woodmaster over the grizzly. Even though it is single drum, they have great support and make an excellent sander, built in Kansas City.
i used them at the Marc Adams school… he has 2 of them (one in each tool room)
