| Forum topic by DogbertBH | posted 460 days ago | 1926 views | 0 times favorited | 18 replies | ![]() |
460 days ago |
Topic tags/keywords: jointers biscuit cutters ryobi dewalt craftsman delta porter cable I truly value anything anyone has to say about these tools. I’m generally a firm believer in buying the right tool the first time, but for right now, I’m just doing stuff for practice and then around the house a little. Getting started with low cost tools for now. These are all tools I can pick up locally, too. Part of the allure is being able to use stuff right away. I’ll probably go for the drill press next. I found 2 Jointers that are similar and more importantly, within my budget. Sears has this Craftsman that’s 6 1/8” VS just 6” Is this something I need to be concerned with?? Rockler has this Delta http://www.rockler.com/product.cfm?page=82&filter=jointer Also, when I get my jointer, I’m also getting a biscuit cutter. There are 3 I’ve seen; Ryobi has the lowest price at $99.00 but if it’s the difference between 99, 189 or 219 I’ll get the one that suits my needs best. http://www.ryobitools.com/powertools/tool/jm82k Sears has one by Dewalt Rockler has the same Porter Cable I saw at Home Depot. (For the same price, too) -- -DogbertBH |
460 days ago |
If you want to but once hold out for the best tool that you can afford. It took me 2 years to have enough to get my unisaw and Have never regretted that decision. I know that I will take some flak but Dewalt are superior to ryobi (In my opinion) and I have used both brands. I also prefer Delta over Craftsamn , but I must confess that I have a Craftsman 14” Bandsaw and like it. You will find that questions about tools will get heated at times because we tend to get that way about our tools.( they are our livelyhood in some ways.) Good luck. -- Hope Never fails |
460 days ago |
I’ve got a Ridgid Jointer and a Port Cable bisquit joiner. They both work. I would prefer a 12 inch Oliver jointer but this one is getting me by for now. I would hesitate on Ryobi or Craftsman. Everything I’ve had from Ryobi has fell apart way too fast. it was lower priced but didn’t hold up. I got lots of Rigid and DeWalt tools. Get the best jointer you can afford and the biggest. But get a jointer even if it’s only a #8 Stanley Bailey Jointer plane. You cannot work with out it. If I have a board over 5 feet I tend to use the plane to joint the edge. The table on the jointer is just too short. don’t forget to have fun!! -- Thos. Angle, Owyhee Design, Oregon |
460 days ago |
I have recently sold my benchtop Craftsman jointer and upgraded to a Powermatic Model 54A 6” jointer – huge difference! The Powermatic is a dream with it’s power and 6’ table! The old Craftsman was OK but it was underpowered and way too short. Save up for a bigger jointer or keep your eyes on CraigsList for a good used one. Delta generally makes good equipment.I would agree with Mr Angle’s comments on Ryobi and Craftsman. We all have our brand preferences, I have had great experiences with Jet, Powermatic and Delta power tools so that is where I spend my money. I have a DeWalt biscuit jointer and it has worked great. I would recommend it. -- Dale, Pittsburgh PA |
460 days ago |
On the question of which biscuit joiner to buy, I have a DeWalt and it is fine BUT, the Porter Cable is better because you can use FF biscuits. “Porter Cable’s faceframe biscuits can join material as narrow as 1-1/2” wide. FF biscuits are 13mm x 30mm with the strength of full size biscuits. Ideal for small picture frames, box corners, and cabinet faces.” The FF biscuits can join narrower pieces which would be a nice feature. The difference in cost is probably $40 – $50 between the DeWalt and the Porter Cable. -- Tom, Surfside Beach, SC - Romans 8:28 |
460 days ago |
That’s a GREAT thing to know about the FF biscuits. I already own the Porter-Cable Finish/Brad nailer kit and a circular saw and have been very happy with both. Although the PC Biscuit cutter is the most expensive, cabinet faces and picture frames are 2 things I had planned on working with. Thanks for that great comment Tom. I plan on getting a thickness planer as well, so I don’t really think I’ll need a giant jointer. And as for the size, couldn’t I just make extensions for larger pieces if I needed them? Like the work table I have at the same height as my table saw… -- -DogbertBH |
460 days ago |
Tom, I’ve tried the FF bisquits and was not very satisfied. I’ve since switched all my face frame work to pocket screws. If you’ve had better luck that’s good but I wan’t happy with the results. -- Thos. Angle, Owyhee Design, Oregon |
460 days ago |
I don’t know if it has changed more reciently, but the PC 557 has been highly rated for quite a while. I have a General 6” jointer. It is a great machine, but I wish I had gotten an 8” machine. (Although, I admit I jones for a 12” cresent or oliver as well) -- We must guard our enthusiasm as we would our life - James Krenov |
460 days ago |
I have the Freud 6.5 amp biscuit joiner from Lowes. $99 and seems well built. |
460 days ago |
Hi Guys; I may as well throw in here. We use Porter Cable biscuit joiners in the shop, and they get some pretty serious use. They have been trouble free, and I recommend them highly. As far as jointers go, get the largest quality jointer you can afford, and also fit in your space. For edge jointing a board, we often use the table saw, simply because its much faster, with the use of a rip sled. Using a sled its one pass thru the table saw, for a glue quality edge, as opposed to four or five passes thru the jointer. We have a photo on our site of the shorter one, and at the bottom of the page, a link to a plan for the larger one, if you want to build one. I guarantee you’ll find these VERY useful. We use these often, especially when we have a large pile of lumber to edge joint. These sleds are also very handy for cutting tapers. That’s accomplished by using double stick tape to hold the board at the angle we want. Here’s the link to the site page: http://www.prowoodworkingtips.com/Table_Saw_Rip_Sled_Plan.html Lee -- by Lee A. Jesberger http://www.prowoodworkingtips.com http://www.ezee-feed.com |
459 days ago |
I would agree with those above on the PC biscuit joiner. I have one and it works great. My jointer is a 6” Ridgid as well. It is a great jointer, but it would be nice to have one of those long bed 12” models instead. But, for my needs it works fine. -- Bill, Turlock California, http://www.brookswoodworks.com |
459 days ago |
Question for Lee: When you “edge joint” a board on the table saw, do you just cut the board with some kind of planer blade? Do you have an edge on the board that is ready for glue-up? -- Tom, Surfside Beach, SC - Romans 8:28 |
458 days ago |
Hi Tom, Sorry I missed this. Hope this explains it for you. Did you check out the link for the rip sled? Or better yet the video on the ezee-feed site. The address is shown in my profile. I’m starring in that production!!! LOL Seriously, I do show using a rip sled on the video, about half way through the seven minute video. But the short answer is I / we use Forrest blades and a ten foot long board will have a glue quality joint, using this method. This will sound far fetched, but you will end up with a straighter board using this method, than using a jointer, especially on long boards. The reason for this is with a rip sled, which is serving the same function as the bed of a jointer, can be as long as you want, whereas there isn’t much you can do about lengthening the bed on a jointer. Another advantage to this is did you ever meet someone that enjoyed changing jointer blades? Since we started straight lining lumber this way, our jointer knives receive very little work, compared to before when we would make five passes on the jointer to get a straight edge. And if the jointer beds are the slightest bit out of alignment with each other, you end up with a bow on what’s supposed to be straight. Instead of making a sled, you could easily just screw the board to a piece of plywood, and ride the fence with the plywood.. That’s my story, and I’m sticking to it Lee P.S. I have a secret. I don’t use pocket holes, I don’t like them. Give me biscuits, or give me death! -- by Lee A. Jesberger http://www.prowoodworkingtips.com http://www.ezee-feed.com |
458 days ago |
Hey, that sounds like a great quote: ”Give me biscuits, or give me death!” - by Lee A. Jesberger Thanks a lot, Lee, for an in depth answer to my question. It’s help like this, from pro’s like you, that is going to make me and others on this forum better woodworkers. -- Tom, Surfside Beach, SC - Romans 8:28 |
458 days ago |
My pleasure Tom; I think I will use that as a quote, good idea!!! Lee -- by Lee A. Jesberger http://www.prowoodworkingtips.com http://www.ezee-feed.com |
458 days ago |
I’ve had a Ryobi bisciut jointer for years. I wish I had bought anything else. -- No piece is cut too short. It was meant for a smaller project. |
457 days ago |
I’ve also found that with a good quality saw blade, you can skip the jointer. I bought an old used Craftsman 6” jointer years ago, & I’ve been highly satisfied with it. I made a nice stand for it. I’ll have to take some pictures of it. -- -** You are never to old to set another goal or to dream a new dream ****************** Dick, & Barb Cain, Hibbing, MN. http://www.woodcarvingillustrated.com/gallery/member.php?uid=3627&protype=1 |
457 days ago |
I can speak concerning Biscuit Cutters. I read a review a while back (Pop WWing, I think) that compared models. The results were very close top to bottom. The biggest factor was fence adjustment. All other variables were very close. I could care less about the fence adjustment. I personally leave it off most the time. All cutters will center to 3/4” stock without a fence. A biscuit doesn’t even need to be in the middle anyhow, just lined up with the other ones. A bought a Freud model from Lowes for right at $100. If you don’t do a ton of angled biscuits the extra $ isn’t worth it in my opinion. If you are going to dish out a lot for a high end cutter, might as well be the Domino. I used a PC model before and it had a better fence adjustment, but cost over $100 more. -- Jeff, South Carolina |
457 days ago |
I had the Ryobi, bought it, and returned it to the Big Box on the same day. Just wouldn’t keep the fence guide parallel on the front. I picked up the DeWalt and have been very happy. -- I am always doing what I cannot do yet, in order to learn how to do it. - Pablo Picasso -- http://snbcreative.wordpress.com/ |
| Sponsor | Forum | Topics |
| Become a sponsor |
Woodworking Skill Share
1336 |
| Become a sponsor |
1778 |
| Become a sponsor |
123 |
| Become a sponsor |
371 |
| Become a sponsor |
108 |
| Become a sponsor |
Woodworking Trade & Swap
251 |
| Become a sponsor |
Coffee Lounge
1003 |
| Become a sponsor |
LumberJocks.com Site Feedback
284 |
