| Forum topic by Rob Drown | posted 178 days ago | 527 views | 0 times favorited | 10 replies | ![]() |
178 days ago |
I am seriously considering this Drill Press. 17” Laser Drill Press. Features Fully adjustable laser pod projects a crosshair on the work piece to indicate the location of bit contact Large redesigned base helps promote greater tool stability Woodworker’s table has a removable insert for through drilling with large bits and accommodates sanding drums as well Unique table is designed to eliminate auxiliary fixtures by tilting left right and forward. It also has a thin flat profile that makes it easier to clamp on fences jigs stops even the work piece itself Large quill stroke capacity allows users to drill a variety of demanding operations Heavy-duty 3/4 HP motor provides ample power for demanding applications Largest in class cast-iron head provides smooth drilling with minimal vibrations Integrated task light provides improved visibility in the drilling area For repeatable hole depths The 17-959L uses a fast single-nut system you push a button to disable the threads and slide the nut over the threaded stop rod. Releasing the button engages the threads for fine tuning the adjustment Manually adjustable belt and pulley system with 16 speeds from 215 to 2720 rpm. Includes 17” Laser Drill Press – 17-959L 3/4 HP Induction Motor 5/8” Chuck Laser Pod 12mm Allen Wrench 5mm Allen Wrench 4mm Allen Wrench 3mm Allen Wrench Drift Key. What do you think? What about a table that tilts every which way? -- Sharp tools and thin whispy shavings make woodworking a joy. |
