First drill press - how far to tap chuck on spindle
Forum topic by AliceAforethought posted 03-08-2015 04:32 PM 893 views 0 times favorited 3 replies Add to Favorites Watch
View AliceAforethought's profile
AliceAforethought
10 posts in 1238 days
03-08-2015 04:32 PM
Hello everyone,
Novice woodworker here. I just purchased my first drill press, WEN 10” 5 speed. When i got to the part in the assembly instructions to install the chuck, it said to tap the chuck on the spindle, but it did not say HOW FAR up the spindle to tap it. So, I tapped it until i determined it could go no more, but there is about a 1/2” gap between the top of the chuck and the groove near the top of the spindle.
The drawing in the instructions shows the chuck all the way to the top of the spindle, but the picture of the assembled drill press online and on the manual cover shows it about 1/2” from the top of the spindle. Of course, there is no customer support on weekends, so i thought I’d ask you…is the chuck OK where it is? I did a test drilling on a 3/4” board with no issues as far as the chuck falling out.
Here's the model from HD.
Thanks for your replies.
3 replies so far
MrUnix
6597 posts in 2166 days
#1 posted 03-08-2015 04:42 PM
Should be a taper fit.. bang it on until it stops and you are done.
4954 posts in 2461 days
#2 posted 03-08-2015 04:46 PM
I looked at the manual, and it looks like you just have a tapered shaft to hammer the chuck onto. It will only go the right distance. Most of them are a Jacobs Taper (though the book doesn’t say)....that will be important if you eve have to replace that chuck.
View helluvawreck's profile
helluvawreck
30765 posts in 2834 days
#3 posted 03-08-2015 05:25 PM
If it ever falls of cleanup the tapers and reset again.
helluvawreck aka Charles
