Broke the teeth on a dado blade
Forum topic by Centuriondk posted 03-08-2015 07:29 AM 1064 views 0 times favorited 6 replies Add to Favorites Watch
View Centuriondk's profile
Centuriondk
1 post in 1146 days
03-08-2015 07:29 AM
Topic tags/keywords: dado broken blade repair
Hi Everyone,
I’m going through the slow process of teaching myself woodworking and I made a newbie mistake.
I purchased on Oshlun 6” dado blade set from Amazon, and thought that my standard throat plate was wide enough to use on 1/4 inch dado cuts. It was close…. but too small. The when I turned on the saw most of the teeth on the outer blade broke in half. I’d hate to have to buy a complete new dado set, since 7 of the 8 blades are still good, but I can’t find anywhere to buy a replacement outside dado blade. I looked into getting the teeth repaired, but that will cost almost as much as a new dado set.
Anyone have any idea where/how to get a replacement blade or if there’s any work around? (All the 6” blades I could find on amazon had 1/2 arbors instead of 5/8’s of an inch).
Any help would be appreciated!
View knotscott's profile
knotscott
7985 posts in 3345 days
#1 posted 03-08-2015 11:29 AM
Try giving Oshlun a call, and tell them what happened….maybe they can help.
View Florida_Jim's profile
Florida_Jim
83 posts in 2847 days
#2 posted 03-08-2015 08:29 PM
You’re right a good sharpening service can braze new teeth on. A dado set has to be sharpened together to ensure flat cuts.
If you could get a new blade, You’d still have to sharpen the set
The cost would probably be close to what you paid.
View TheFridge's profile
TheFridge
9256 posts in 1456 days
#3 posted 03-08-2015 08:34 PM
Pretty much.
View bondogaposis's profile
bondogaposis
4690 posts in 2321 days
#4 posted 03-08-2015 08:37 PM
Unless you can get another blade from Oshlun, I think you are screwed. You need to make an insert out of something besides steel.
-- Bondo Gaposis
View ElChe's profile
ElChe
630 posts in 1306 days
#5 posted 03-08-2015 09:00 PM
If it is new then I think you’d be fine if you can source a replacement. I doubt that Oshlun individually shapens each dado set.
Per Oshlun website how to contact:
Thank you for your interest in Oshlun, Inc. If you have any questions or need any product assistance, please call us at 702-294-1231 or email us at info@oshlun.com. You may also fill out the below form and we’ll get back to you quickly.
Good luck. Tom
View CharlesA's profile
CharlesA
3312 posts in 1767 days
#6 posted 03-08-2015 09:03 PM
I checked with my Amana dado set one time, and it was cheaper to replace the set than to but a replacement outer blade.
