Can you ID this plane blade
« back to Hand Tools forum
Forum topic by Paul M posted 03-08-2015 03:54 AM 769 views 0 times favorited 5 replies Add to Favorites Watch
View Paul M's profile
Paul M
117 posts in 1326 days
03-08-2015 03:54 AM
Topic tags/keywords: plane iron stanley 3
I picked up a Bailey no3 (type 11, I think) a few weeks ago, and am starting the restoration. Found this iron in it. Any ideas what it is? Can I use it? I don’t recognize the iron logo. Thanks all.
-- Paul M
5 replies so far
View DocBailey's profile
DocBailey
584 posts in 2383 days
#1 posted 03-08-2015 04:24 AM
It says REVONOC
It’s Conover spelled backward; right now can’t remember who he was, but I think this was a product of the old Hibbard, Spencer & Bartlett hardware chain.
I’m sure googling those terms will get you more info than you ever wanted.
——————————as to your 2nd question———————————————————————-
No reason why you can’t use it (assuming you can sharpen it—but there’s not a whole lot of sharpenings left in that one (note how close cutting edge is to bottom of slot)
View TheFridge's profile
TheFridge
9606 posts in 1509 days
#2 posted 03-08-2015 04:34 AM
Paul M
#3 posted 03-08-2015 04:43 AM
Wow, the knowledge level on this forum is unbelievable, thanks so much. I will try to use the iron. It will go into the molasses bath tomorrow (can be slow, but removes only the rust, and is real cheap). Then will see if I can get a sharp edge out of whats left.
Thanks again.
-- Paul M
View ElChe's profile
ElChe
630 posts in 1359 days
#4 posted 03-08-2015 05:11 AM
If the flat side is pitted toward the front inch or so I’d get a replacement iron. If it is just surface rust then flatten and polish the last inch or so of the flat side and get it sharp and make some shavings.
View JayT's profile (online now)
JayT
5673 posts in 2234 days
#5 posted 03-08-2015 04:02 PM
It says REVONOC
It s Conover spelled backward; right now can t remember who he was, but I think this was a product of the old Hibbard, Spencer & Bartlett hardware chain.
I m sure googling those terms will get you more info than you ever wanted.
No reason why you can t use it (assuming you can sharpen it—but there s not a whole lot of sharpenings left in that one (note how close cutting edge is to bottom of slot)
- DocBailey
What he said. Conover was the gentleman that was in charge of sourcing tools for HSB & Co for many years and the Revonoc line was to honor him and his work.
