Drilling/Routing Advice
Forum topic by Obie posted 03-08-2015 01:29 AM 895 views 0 times favorited 16 replies Add to Favorites Watch
View Obie's profile
Obie
24 posts in 3095 days
03-08-2015 01:29 AM
Oh great and wise lumberjocks, I see insight.
Pictured below is something I am contemplating. The material will be Goncalo Alves. I want to drill the holes on the top a 1/2” diameter and then route the grooves on the side with [whatever bit I can find]. I want the routed groove to cut through to the drilled holes (ignore the yellow and just pretend you can see into the drilled holes).
If I drill first then route will I risk chipping/chunking when I pass through the drilled holes? Or, vice versa, if I route the groove first will I mess up the holes as I drill them? Or, both?
I kind of wanted to drill the holes first so I could sneeak up on the final depth of the groove using multiple passes.
Material will be Goncalo Alves. Will be using a drill press and a router table. So, none if it will be fumbling by hand.
It’s an $8 block of wood and I really don’t want to learn the hard way… I have learned a lot of things on the router the hard way but, none of them have involved blood, yet.
What are your thoughts? Thank you in advance!
-- "Measure Once, Curse Twice"
16 replies so far
View Obie's profile
Obie
#1 posted 03-08-2015 01:32 AM
Hmmm, image didn’t quite come out right but well enough to get the idea….
View EEngineer's profile
EEngineer
1102 posts in 3609 days
#2 posted 03-08-2015 01:36 AM
I think you risk tearout more drilling after routing. In my experience, tearout is worse drilling through an open space with no backer. I have routed through existing holes many, many times with no tearout.
Drill first, then route.
View Patch2020's profile
Patch2020
97 posts in 1237 days
#3 posted 03-08-2015 01:41 AM
You might try drilling first, then insert some 1/2” dowels into the holes. The difference in the dowel and the block will let you see well enough to set depth while filling the space and helping with tear out.
-- Patch2020, Tennessee
View Obie's profile
Obie
#4 posted 03-08-2015 01:59 AM
Excellent! Experience and ingenuity. Thank you both!
18159 posts in 1852 days
#5 posted 03-08-2015 02:03 AM
I agree with drilling first. Less likely to get tear out at 18,000 rpm than with 1200 rpm.
View Obie's profile
Obie
#6 posted 03-08-2015 02:03 AM
Whoa… That gives me another idea for the future. Drill the holes over-sized, route the groove, then fill the drilled holes with a contrasting color of hardwood dowel and drill the final hole through the center of the dowel. That might look really interesting!
#7 posted 03-08-2015 02:07 AM
If you do that then your routed groove won’t open into the drilled hole unless you then go back and reroute the groove, in which case you’ll be right back where you started.
View Ghidrah's profile
Ghidrah
667 posts in 1218 days
#8 posted 03-08-2015 02:18 AM
If no one else suggested it already how about filling the drilled holes with dowels, this will minimize and or eliminate tear out.
-- I meant to do that!
View Obie's profile
Obie
#9 posted 03-08-2015 02:43 AM
If you do that then your routed groove won t open into the drilled hole unless you then go back and reroute the groove, in which case you ll be right back where you started.
- firefighterontheside
If I did that, I would not reroute the groove. The dowel fillers would be left exposed in the groove and add a little more dimension. Just like the picture (not ignoring the yellow parts this time)I posted except with larger holes/dowels.
View MT_Stringer's profile
MT_Stringer
3168 posts in 3227 days
#10 posted 03-08-2015 02:52 AM
What the heck is that anyway?
#11 posted 03-08-2015 02:55 AM
Ah, I see. I was under the impression you wanted a hole to be open between the hole and the groove.
View Obie's profile
Obie
#12 posted 03-08-2015 04:35 AM
- MT_Stringer
It’s going to be a …. holder? for 20 rounds of .308
View Obie's profile
Obie
#13 posted 03-08-2015 04:48 AM
Something like this except I was just trying to make it unique.
View TheFridge's profile
TheFridge
9446 posts in 1482 days
#14 posted 03-08-2015 04:54 AM
- Obie
That sounds pretty awesome.
MT_Stringer
#15 posted 03-08-2015 05:17 AM
Pretty cool.
