Dust Collector Recommendation for a Basement Workshop?
Forum topic by stefon posted 03-08-2015 12:33 AM 1686 views 0 times favorited 7 replies Add to Favorites Watch
View stefon's profile
stefon
14 posts in 1577 days
03-08-2015 12:33 AM
I was looking for some recommendations for an adequate dust collector for a basement workshop. I am currently using a Fein Turbo II which works well for some tools such as a table saw, but it is not appropriate for a belt sander. I also recently purchased one of those box units that you hang from the ceiling. That works well but I need a serious dust collector as my power tool collection expands. I currently have a belt disc sander, planer, oscillating Ridgid Sander, router table, and a few other small ones.
I am not wired for 220, so it would have to be something that works 120v.
I appreciate everyone’s suggestions.
Stefon
7 replies so far
View bbasiaga's profile
bbasiaga
1234 posts in 2020 days
#1 posted 03-08-2015 03:36 AM
I went with the Harbor Freight 2hp unit, and upgraded the filter to a Wynn Merv 15. Haven’t tried it much yet, but it was relatively affordable. it rolls around so I just hook the hose up to whatever I’m using at the time. Saved big on ducting, bigger fans, etc.
-Brian
View SST's profile
SST
790 posts in 4219 days
#2 posted 03-08-2015 03:52 AM
I also have a HF unit & it works very well. Watch for a sale or use a 20% off coupon that seem to be everywhere. You can spend a lot more & not do any better.
-- Accuracy is not in your power tool, it's in you
View mandatory66's profile
mandatory66
202 posts in 2155 days
#3 posted 03-08-2015 03:56 AM
I have a JDS 1.5 HP Dust force filter & a JDS box filter up on the ceiling. I am very satisfied with the Company & their products. Had purchased a dust filter made in China and the quality was so bad I sent it back. That was a bout 7 years ago so things may have changed. I roll my filter around the basement to whichever machine I am using. for the small stuff like my router table I us a Rigid 12 gallon Vac.
View DIYaholic's profile
DIYaholic
19623 posts in 2700 days
#4 posted 03-08-2015 04:09 AM
+1 on the HF 2HP DC with the upgraded Wynn Environmental 35A Cartridge filter.
I have added a (shop made) Thein Top Hat pre-separator with a 30 gallon metal trash can collection bin.
The most cost effective DC solution, for a small basement shop.
View pandamonium54's profile
pandamonium54
10 posts in 1698 days
#5 posted 03-08-2015 04:52 AM
I went back and forth about a proper DC vs shopvac. To be fair, I recognize I’m more caught up in the gear acquisition phase than actually building stuff right now.
I wasn’t willing to spend money on a DC unless it either vented outside or the exhaust was HEPA clean. Wynn’s filters come close to HEPA standards. The issue I had is this: HF DC + Wynn filter + separator was coming in around 550+ depending on the separator. Plus I’d probably have to spend some money on tools to cobble the thing together.
Something like a Grizzly G703P is all-in-one, was the cyclone design I preferred, close to HEPA, and was $900 delivered, with no extra fiddling.
... If I were looking at $900, then it’s not too much more for something like a Mini-Gorilla, which is definitely HEPA.
... But then a Oneida V-System is also HEPA, and much beefier than the mini Gorilla, only for a couple hundred more.
... But then people seem to be universally happy with the ClearVues, and that design is approved by Pentz himself. And it’s only a bit more. Too bad it wouldn’t fit.
... But if I knock out the floor underneath the kitchen maybe I could….
At that point, I realized I had talked myself up to $2k for a dust collection system for a hobby that I couldn’t be sure was a fad or a lifelong hobby. The point is, it’s ridiculous.
So I went with a Ridgid WD1450 (not much more airflow than your Fein), stuck a HEPA filter in it, connected it to a cyclone separator, and use it at the tool with a mask. I let the sawdust settle and vacuum it up the next day. Probably doesn’t solve your problem exactly, but what I’m trying to say is that if you’re anywhere near my beginner stage, I’d recommend sticking with stuff that can be repurposed if you find you’re not as interested in it as you thought you’d be.
pandamonium54
#6 posted 03-08-2015 05:00 AM
Actually, re-read your post and thought some more.
My point above still stands, but if you’re just struggling with your sanders, why not build a small acrylic cabinet around them? From the stuff I’ve read, sanders and SCMS are notoriously difficult to contain. Hell, even the Kapex leaves a nice pile of sawdust. Unless you’ve got the budget, space, and electrical for a super high CFM system, it might be easier to just contain the sawdust enough that your Fein can keep up with it.
View English's profile
English
658 posts in 1502 days
#7 posted 03-08-2015 02:01 PM
Not having 220 available is going to make it very hard for you to find a DC that will product enough static pressure to handle a separator, filters and a duct system. So I think you will be limited to the smaller portable systems like the HF or one of the other roll a rounds with a cartridge filter.
If you are planning on duct work, use this spreadsheet to find out how much static and cfm you need. www.billpentz.com/woodworking/cyclone/staticcalc.xls
-- John, Suffolk Virgina
