Grinder Questions
« back to Woodturning forum
Forum topic by Charlie75 posted 03-07-2015 10:14 PM 1051 views 0 times favorited 10 replies Add to Favorites Watch
View Charlie75's profile
Charlie75
310 posts in 2169 days
03-07-2015 10:14 PM
I am thinking about getting a bench grinder and learn to sharpen my own tools.
Been watching Craigs list but not much comes up. There are a lot of grinders but they are mostly 6” high speed.
This raised the question in my mind, would a 6” high speed grinder work.
High speed vs low speed. 6” vs 8” and 1/2 hp vs 3/4 hp. all raised questions in my mind.
Charlie
-- Charlie75, Alto
10 replies so far
View TheDane's profile
TheDane
5366 posts in 3567 days
#1 posted 03-08-2015 01:15 AM
Charlie … You can get by with a 6” high-speed grinder. A lot of turners have been using them for years with great success.
You just have to make sure you put friable wheels on it (the grey wheels most come with are not appropriate for sharpening HSS tools) and above all, take it easy to avoid grinding away too much steel.
That being said, by the time you buy a high speed 6” and replace the wheels, you will probably spend close to what you would pay for the Rikon slow speed with friable wheels at Woodcraft ( http://www.woodcraft.com/Product/158512/Rikon-8in-Slow-Speed-Grinder.aspx ).
I have a 1/2 hp slow speed that I bought from Woodcraft four years ago … it has been fine.
View ElChe's profile
ElChe
630 posts in 1241 days
#2 posted 03-08-2015 04:53 AM
I’ve been using a cheapo free 3450 8” grinder with a Norton white wheel with no problems on plane irons and chisels. I keep a little container of water and dip when steel gets uncomfortable on my finger tip. Light touch. Works great. I think a 6” wheel would effectively run slower if my mind math is correct. But my mind like my wheel is friable. I did get a decent tool rest because the cheapo grinder came with a usless tool rest.
View LeeMills's profile
LeeMills
503 posts in 1205 days
#3 posted 03-08-2015 04:53 AM
I agree with the above.
I have use a 6” grinder with no problems (abt 35 years). If new I would go with the low speed and 8”.
A light touch is all you need with either.
Charlie75
#4 posted 03-08-2015 12:08 PM
My original question may have been a bit misleading. I was referring mainly to turning tools. Of course I want to grind chisels and plain irons too.
There are many 6” high speed grinders available in my area at prices that fit my budget at this time but I don’t want to get something that won’t work at any price.
Where do you guys get your grinding wheels?
Charlie
-- Charlie75, Alto
View jdh122's profile
jdh122
983 posts in 2722 days
#5 posted 03-08-2015 12:23 PM
Turning tools are even easier to grind on a regular grinder than chisels and plane blades, because high speed steel is less likely to burn than carbon steel. Any 6-inch regular grinder will work, you just need to make sure you gave an aluminum oxide wheel (white, friable). You need to make sure to dress the wheel often, cause if it glazes over it’ll burn your tool in no time flat.
I bought mine at Lee Valley, but all of he regular woodworking sources sell the wheels (Woodcraft, HIghland, Rockler, Amazon and no doubt many others).
TheDane brings up a good point. Include this extra wheel purchase in your calculation in comparison to the RIkon or similar grinder that comes pre-outfitted with these wheels. Personally I don’t think it’s necessary to have two white wheels, though. I left on the regular, included wheel to use occasionally for non-tool grinding.
-- Jeremy, in the Acadian forests
LeeMills
#6 posted 03-08-2015 02:53 PM
A little OT but I never grind my chisels (bench or lathe). I like them razor sharp so just a few passes to hone brings them back. To grind you would be starting all over. For the lathe I hone the skew, parting tool, and the small cutters which are hard to grind.
ElChe
#7 posted 03-08-2015 03:27 PM
Lee Valley or Sharpening Supplies carries the Norton white friable wheels.
View waho6o9's profile
waho6o9
8099 posts in 2481 days
#8 posted 03-08-2015 04:15 PM
http://www.ebay.com/sch/i.html?_from=R40&_trksid=p2050601.m570.l1313.TR0.TRC0.H0.X8%22+slow+grinder.TRS0&_nkw=8%22+slow+grinder&ghostText=&_sacat=0
HTH
I purchased a similar one a few years back with the friable wheels and
she’s still working fine.
View TimberMagic's profile
TimberMagic
114 posts in 1083 days
#9 posted 03-09-2015 07:32 AM
I have a Delta 6” grinder, and did put one Norton wheel on it for grinding lathe chisels. I have to raise it up now since I just bought a Wolverine jig, and my setup lacks the necessary clearance/height. I’ll get an 8” slow speed grinder next year, and I am really anxious to get CBN wheels. Check out D-Way Tools for info and videos if you are not familiar. They are expensive, but are really impressive. CBN grinding wheels are coated metal wheels. They need no wheel guard since they will not fracture and fly apart.
I just saw a turning demo this week at Woodcraft. The turner had two 8” grinders set up with 4 CBN wheels (platforms set at different angles for grinding different tools). Really a nice setup. That is over $700 just in wheels!
-- Lee
View whitetimothyaus's profile
whitetimothyaus
1 post in 1079 days
#10 posted 03-09-2015 11:03 AM
I have 6” grinder and it is working really very well.
-- http://www.energysavingsblinds.com.au
