Has anyone made alphabet blocks?
Forum topic by tomakazi posted 06-02-2009 08:27 PM 3961 views 0 times favorited 10 replies Add to Favorites Watch
View tomakazi's profile
tomakazi
686 posts in 3245 days
06-02-2009 08:27 PM
Topic tags/keywords: jig router carving shaping
I wanted to make same alphabet blocks for my daughter. I’ve seen some on LJ that are just blocks with stamped letters. I want to make some with the letters and numbers raised. They will also have a raised boarder. Any ideas will be helpful (wood types, jigs and anything else you can think of).
THANKS,
Tom
-- I didn't go to college, I was too busy learning stuff - Ted Nugent
10 replies so far
View pommy's profile
pommy
1697 posts in 3653 days
#1 posted 06-02-2009 08:36 PM
Hi Tomakazi
I have made blocks before but i sort of cheated all i used was 4”x4” softwood timber and i routered the letters in one side and numbers the other so as for raised letters you could draw the letter and boarder and introduce yourself to carving lol thats all i got hope it helps
Andy
-- cut it saw it scrap it SKPE: ANDREW.CARTER69
View Rustic's profile
Rustic
3253 posts in 3558 days
#2 posted 06-02-2009 08:45 PM
I made some for my niece once. I had a 2×2 (i think) cut it to a size I thought that she could handle and used stencils to lay out the letters and then wood burned them in
tomakazi
#3 posted 06-02-2009 08:45 PM
Thanks Andy
I wanted to keep them around 2”. I also wanted to make them with 1 letter per block and enough to spell her name TARISSA CONILEE RICHARDSON. All that times 4 is a lot of carving. I have some high end carving tools that i picked up at a pawn shop, about $600 worth for under $100. this was about 3 years ago and I haven’t made time for them yet.
tomakazi
#4 posted 06-02-2009 08:49 PM
Thanks Rustic I didn’t think of that. I want to keep the natural wood color.
pommy
#5 posted 06-02-2009 09:05 PM
Dave thats not so stupid as it sounds as for the laser machine they would be mighty expensive alphabet blocks
lol…....
Andy
tomakazi
#6 posted 06-02-2009 09:06 PM
Thanks DaveR
I haven’t thought about either one of those ideas. Laser is quite an expence for some building blocks. I’ve never sand blasted wood before.
tomakazi
#7 posted 06-02-2009 10:34 PM
I used a sand blaster on granite before. I cut patterns out of rubber then applied with rubber cement. that worked great. I have also been doing a lot of glass work the past few years, I would like to get a sand blaster that’ll work for etching.
View lew's profile
lew
12015 posts in 3717 days
#8 posted 06-02-2009 10:37 PM
If you can find someone who has taped all of the New Yankee Workshop episodes, in season 6 Norm made an alphabet wagon. He made the type of blocks you are looking for. I searched the NYW web site but for some odd reason, that project is not listed.
tomakazi
#9 posted 06-02-2009 10:45 PM
Thanks lew
I’ll check that out. if I can’t find it I’ll e-mail and ask.
View Peter Oxley's profile
Peter Oxley
1426 posts in 3836 days
#10 posted 06-02-2009 11:30 PM
Maybe you could find someone with a Compucarve to put the letters and numbers in a long blank, then separate the blocks with the miter saw?
-- http://www.peteroxley.com/woodworking -- http://north40studios.etsy.com --
