stile and rail fit
« back to Joinery forum
Forum topic by KellyB posted 03-07-2015 07:46 PM 751 views 0 times favorited 5 replies Add to Favorites Watch
View KellyB's profile
KellyB
77 posts in 1053 days
03-07-2015 07:46 PM
I copied this image from another post here.
My question has to do with the fit of the tenon in the mortise. There is a bit of a gap between the end of the tenon and the bottom of the mortise. Is this normal? Or is there a bit of bad machining in my Freud bit set. There is a provision for lengthening the tenon and mortise which I could use to lengthen just the tenon a bit. The difference is only about .025, and while it is not a lot, it is still visible.
Am I being nuts? (be kind) or is this to allow for some sort of expansion. or what.
Thanks again.
5 replies so far
View jerryminer's profile
jerryminer
846 posts in 1312 days
#1 posted 03-07-2015 07:53 PM
I would leave it alone. The advantage of a small gap there is that it ensures that the joint will close up tight at the surface, where it shows
View bondogaposis's profile
bondogaposis
4525 posts in 2222 days
#2 posted 03-07-2015 08:11 PM
Yes, that is normal and advantageous. It allows a gap free fit on the face.
-- Bondo Gaposis
View Patch2020's profile
Patch2020
97 posts in 1112 days
#3 posted 03-07-2015 08:32 PM
It allows the surface to fit flush while allowing room for the glue in the joint.
-- Patch2020, Tennessee
KellyB
#4 posted 03-07-2015 09:58 PM
thanks all.
I think I have learned more on this forum in a week than I have in quite awhile.
View cabmaker's profile (online now)
cabmaker
1664 posts in 2680 days
#5 posted 03-08-2015 12:14 AM
While there is some validity to bondos post looks like u need to tweak your height adjustment a tad. You’ll know when it’s on
