Jet 6" jointer
Forum topic by Pbarter posted 03-07-2015 05:52 PM 720 views 0 times favorited 2 replies Add to Favorites Watch
View Pbarter's profile
3 posts in 1121 days
03-07-2015 05:52 PM
I recently purchased a jet 6” jointer off Craig’s list. I have a couple issues with it. First when I try to raise or lower the infeed table the hand wheel seems to be stuck. The safety pin in the rear is engaged and I’m not able to release it. Anyone have a similar issue? Second when I try to edge joint a board after face jointing it is not. 90 degrees. When the fence is square to the infeed table it is slightly off on the out feed table. Is this a coplaner issue? Any help would be appreciated. Thanks
2 replies so far
View pintodeluxe's profile
5596 posts in 2749 days
#1 posted 03-07-2015 11:02 PM
Yep, you need to pull the safety pin. It is there to prevent the operator from making cuts deeper than 1/8”. However, it needs to be released to go back to a typical light cut. Move the height adjustment crank a little bit to free the pin.
The fence out of square could be due to a coplanar problem (most likely problem). Use brass shims to bring all four corners of the outfeed table into one plane, square to the fence.
The fence could also be warped (less likely problem).
Good luck with it.
View ElChe's profile
630 posts in 1272 days
#2 posted 03-07-2015 11:08 PM
Check each wing with a straight edge. Then check both wings with straightedge and feelers to see if coplanar. Only way to adjust the coplanarity of the wings is with shims in the dovetailed ways as suggested. I used coke can strips on mine but I stupidly adjusted the infeed wing so I leave it set to take a light cut. Someday I will shim the out feed table. The safety pin should come out with some patience. I take about a 1/32” per pass and it works like w charm.
