How to make this cut?
Forum topic by BrandonR posted 03-07-2015 04:26 PM 788 views 0 times favorited 6 replies Add to Favorites Watch
View BrandonR's profile
BrandonR
64 posts in 2198 days
03-07-2015 04:26 PM
I am working on making a large number of boxes/cradles for a client… They want this oval shape in the picture… At first I cut a circle in the wood then just used table saw to get the straight lines…. that left a small cut mark on back thought where I started…
This piece is really small only 3 inches by 4inches… What would be best to make an initial template and than make it repeatable?
Thanks!
View TheFridge's profile
TheFridge
8882 posts in 1391 days
#1 posted 03-07-2015 04:39 PM
Yep
View SASmith               's profile
SASmith
1850 posts in 2892 days
#2 posted 03-07-2015 06:05 PM
I would cut a 1/4” thick template with a bandsaw then sand to the line.
Double sided tape the template to the actual piece and then template route on the router table.
-- Scott Smith, Southern Illinois
View Patch2020's profile
Patch2020
97 posts in 1146 days
#3 posted 03-07-2015 06:10 PM
SASmith has the right idea.
-- Patch2020, Tennessee
116904 posts in 3482 days
#4 posted 03-07-2015 06:24 PM
If I had a large number of these to make I think I would set up some stops on the drill press with the correct size forester bit and drill the round part out(perhaps several at a time) then use a pattern to draw The lines for the opening, band saw ,then clean up by sanding with a oscillating spindle sander and or a 1” belt sander(HF sells them fairly cheap)
MrUnix
6348 posts in 2104 days
#5 posted 03-07-2015 06:32 PM
Stack cut your pieces to rough shape using whatever you have.. band saw, jig saw, scroll saw if thin enough, etc.. then finish them up with a router using a template like SA mentioned. You could whip them out pretty quickly and the router should leave a nice surface that only requires minimal sanding to complete.
View Garbanzolasvegas's profile
Garbanzolasvegas
356 posts in 1132 days
#6 posted 03-07-2015 07:08 PM
-- If you don't Play, you can't win
