| Forum topic by MyFathersSon | posted 176 days ago | 468 views | 0 times favorited | 19 replies | ![]() |
176 days ago |
Topic tags/keywords: question router PATIENT Craftsman 17542 1/2” router mounted in table. SYMPTOMS QUESTION——I don’t expect any solid solutions from such general symptoms but—- Unfortunately – it is out of warranty so if they work on it – I am looking at minimum $60 to repair a $90 router. -- Those who insist it can't be done - should politely refrain from interrupting those who are doing it. |
176 days ago |
I can only guess that the brushes are dirty, or need to be replaced. I have worked with buffers for many years, and the symptom is as you described. You will have to look for the screw cap that is 180 regrees from the other, remove the brush which should be attached to a wire and a thin washer with the wire where the hole should be. Clean it very carefully. I believe that alkacahol will leave no deposit carefully clean the armature with clean lint free cloth. the brushes are the blocks attached tp the wire, and one normally wears more that the other. replace if more than 1/2 is there, or there is evidence of the wire mount is showing. Hopefully, you will be able to take care of it. If you can see the brush area when it is runninf, there should be little spark showing. when dirty, or worn you will see a much larger spark trailling. this will be the sign to replace, or repair. I wish you well. It is not very hard to do, normally. altho some are much harder than others. -- Saved, and so grateful, consider who Created it ALL!!! |
176 days ago |
My guess is the bearing closest to the base has gone bad, since that is where the heat is hottest. Brushes are on the opposite end and don’t normally get that hot or make bad noises even when worn out. -- Joe |
176 days ago |
My guess would be the bearing too. -- Debt is nothing more than the 21st Century's form of slavery. |
176 days ago |
Bearing -- Only the Shadow knows.................... |
176 days ago |
Get a new set of brushes and a couple of bearings and you should be good for a while. Bob -- A mind, like a home, is furnished by its owner |
176 days ago |
Thanks guys—I had pretty much guessed bearings too. Secondary question would be wondering what I did to kill them and how I can NOT do it again. -- Those who insist it can't be done - should politely refrain from interrupting those who are doing it. |
176 days ago |
I’ve never popped the case on a router either, so I don’t know if it is user friendly on that or not. If the bearings are that bad, I wonder if the shaft is damaged too?? -- Debt is nothing more than the 21st Century's form of slavery. |
176 days ago |
You may have found the problem. The place of most consern is the brushes and commutator. The next thing is to hope that the bearing will slide out. I would think that it is worth your time to try, By the time that a professional is done, the router may be better replaced. -- Saved, and so grateful, consider who Created it ALL!!! |
176 days ago |
Re: taking it apart, etc. – I’d go for it. There isn’t that much stuff inside, and what do you have to lose? It is junk now, taking it to a pro would cost more than it’s worth, and you might be able to fix it! (If it can’t be fixed, it would be an interesting paper weight. ;). Re: Why was the life so short – Who knows, could have been a random failure. What you are doing doesn’t seem to be abusive, unless you are making cuts that are too deep with a lot of side load on the bit. The main reason might be that it was a “cheap” router to begin with. Next time I’d go with a PC, Dewalt, etc. (Check the “My Router Died” thread to see what’s popular. -- Joe |
176 days ago |
Give it a try. What can you hurt? It is already broke, if you fix it, great, if not, SHOPPING! Looks like a win, win to me. Gotta have fun -- Berta in NC |
176 days ago |
ajose—you are right about the use— Guess that means you may be right on the quality Thanks for the encouragement. Fortunately – I have a spare that will get me through this current project. Thanks again. -- Those who insist it can't be done - should politely refrain from interrupting those who are doing it. |
176 days ago |
my 2 cents toss it out and buy a new one I woudn’t waste 60 bucks fixing this if it’s so badly worn out.Alistair -- excuse my typing as I have a form of parkinsons disease |
159 days ago |
Let us know how the router is turning out. It’s nice to follow the results, it gives us all something to check if ours heads south. -- Saved, and so grateful, consider who Created it ALL!!! |
152 days ago |
Thanks for asking—managed to get everything done that required table before the router died—been busy with other parts of the project—oh and my ‘real’ job. -- Those who insist it can't be done - should politely refrain from interrupting those who are doing it. |
152 days ago |
You may find some help from this site: http://powertool.manualsonline.com/ -- Saved, and so grateful, consider who Created it ALL!!! |
151 days ago |
Try this: |
149 days ago |
If you search on Google, you can probably find an exploded parts drawing for your brand/model router. This should be a help when taking it apart and trying to find the replacement bearing (partsdirect.com usually has what I’m looking for). Jim |
108 days ago |
Well – it has been a crazy month—but I finally ordered the bearing from Sears. -- Those who insist it can't be done - should politely refrain from interrupting those who are doing it. |
54 days ago |
I did one more small project with the repaired router. -- Those who insist it can't be done - should politely refrain from interrupting those who are doing it. |
| Forum | Topics |
Woodworking Skill Share
2911 |
3936 |
256 |
947 |
223 |
Woodworking Trade & Swap
617 |
Coffee Lounge
2378 |
LumberJocks.com Site Feedback
522 |
