Smoothing plane lapping question
« back to Hand Tools forum
Forum topic by woodenwarrior posted 03-07-2015 02:46 AM 1084 views 0 times favorited 14 replies Add to Favorites Watch
View woodenwarrior's profile
woodenwarrior
225 posts in 2101 days
03-07-2015 02:46 AM
Topic tags/keywords: plane lapping sole recondition
I picked up a Stanley #4 1/2 smoother ( circa 1890ish according to Patrick’s Blood and Gore) about a year and half ago for $5. The handle was busted in half and irreparable and it was a serious contender for the golden plane award (rust) but I really wanted a #4 1/2 to add to my fledgling collection. Other than those two issues the plane is in fairly good shape. I made a new rear handle in walnut using the free download plans from Lee Valley ( I love those guys!) and with a healthy amount of sweat and elbow grease have brought it from a junk pile special back to a fine looking and (hopefully) working specimen. The one question I’m having is lapping of the sole. I have it dead flat front to rear except for a 1/4 inch border all the way around the sole’s edge which still bear scratch patterns from lapping. It tells me the sole was convex but the major working areas are dead flat. Will that affect the plane’s performance?
-- Do or do not...there is no try - Master Yoda
14 replies so far
View jmartel's profile
jmartel
7687 posts in 2057 days
#1 posted 03-07-2015 03:46 AM
If it’s flat everywhere else, it’s probably good enough. I might continue till it’s gone or about 1/16” remaining, but that’s me. Test it out. If you can get full width/length shavings, it’s good enough.
View lateralus819's profile
lateralus819
2241 posts in 1796 days
#2 posted 03-07-2015 03:53 AM
Sounds to me like it was done on purpose which was typical to avoid the edges from catching on the work piece.
Paul sellers has a video explaining the process and the reasoning.
https://www.youtube.com/watch?v=zQyjLV92224
Starts at about 3:40 mark. Hope this helps.
woodenwarrior
#3 posted 03-07-2015 04:38 AM
Thanks for the tips. I have a Hock iron for the plane but I want to make sure that I’ve taken the sole lapping far enough to use.
View DocBailey's profile
DocBailey
584 posts in 2267 days
#4 posted 03-07-2015 06:08 AM
The proof is in the pudding—there is no reason to mess any further with the sole if the plane can take thin, full-width shavings.
TheWoodenOyster
1313 posts in 1842 days
#5 posted 03-07-2015 03:49 PM
I bet you are good to go. I actually slightly slope my plane edges up like yours is to keep them from digging into wood that isn’t flat. I’d bet $10 yours is ready to work.
-- The Wood Is Your Oyster
View ElChe's profile
ElChe
630 posts in 1243 days
#6 posted 03-07-2015 04:01 PM
+1 what Kevin and Oyster said. Probably done on purpose a la Paul Sellers to prevent banging the plane into the wood being planed. My first plane rehab I dutifully lapped or fettled the bottom of a no.4 perfectly flat. Then I got smarter (or lazier) and on a second no. 4 I simply waxed the sole and tried it with a freshly sharpened iron and gosh darned if it didn’t cut just as nice as the fettled plane. I now check for flatness at toe and in front of mouth and at rear. If decently flat in those three areas it is good to go.
woodenwarrior
#7 posted 03-07-2015 07:14 PM
Having the edges relieved to preclude catching the wood makes sense. I’ll do some final touch ups on the plane and give her a test run this evening.
Smitty_Cabinetshop
15121 posts in 2525 days
#8 posted 03-07-2015 07:30 PM
Good luck, sounds like you are ready to go. Love me some #4 1/2 action, so pics are a must!
View Don W's profile
Don W
18606 posts in 2474 days
#9 posted 03-08-2015 01:35 AM
Pictures or it didn’t happen.
woodenwarrior
#10 posted 03-08-2015 01:11 PM
Like a dummy I didn’t take any before photos…but trust me, it was in poor shape. Here are the results from my work.
woodenwarrior
#11 posted 03-08-2015 01:31 PM
First test run on maple…...success!!!! Thanks to everyone for their input on this.
Don W
#12 posted 03-08-2015 02:06 PM
Excellent!
View HorizontalMike's profile
HorizontalMike
7747 posts in 2821 days
#13 posted 03-08-2015 02:24 PM
WOW! Now THAT is almost to get me to start collecting Stanleys… Well almost, I love Sargent planes to much… ;-) You did an excellent job restoring this! Congrats and welcome to the club! Well done.
RE: flattening the sole 100%... As others have said/implied above, if you have 80-90% of the sole flat then you are good to go. FWIW, while not a metal handplane, I have an old 1850-ish 22” Wooden Jointer that had developed a twist in the past +160yr. I ended up running the sole of this Beech plane over my jointer and managed to flatten the sole 90% or so, but still had of aft corner that was still shy. I stopped in order to keep the throat/mouth width as tight as I could. It works great!
http://www.horizontalheavens.com/auburn_tool_co_22in_Jointer.htm
You’ll be fine with the extent that you have flattened it. Isn’t this fun!
View sikrap's profile
sikrap
1121 posts in 3266 days
#14 posted 03-08-2015 02:32 PM
Nice save!!
-- Dave, Colonie, NY
