more seriously though, I take it you are wanting the blind to follow the curve?
Grab some paper on a roll, like wrapping paper or construction paper and create a scribe using a stick with a dowel on one end and a pencil in the other. Tape the paper to the wall, and follow the curve with the dowel creating a concurrent radius or just trace the curve of the window for an exact copy. Then you can measure and do the math to figure radius. Finally transfer it to a sheet of 1/2" mdf or 1/4" hardboard for a pattern.
Remember the radius increases as you outward from the center point of the arc.
If it's round do as David suggest if it's oval make a pattern with paper ,cardboard or thin strips of wood hot glued together and use your pattern to make your window blind.
Related Threads
LumberJocks Woodworking Forum
2.5M posts
96K members
Since 2006
