Screw Loose
Forum topic by DannyBoy posted 175 days ago 213 views 0 times favorited 7 replies Add to Favorites Watch
View DannyBoy's profile
DannyBoy
442 posts in 758 days
175 days ago
Topic tags/keywords: bandsaw tap and dye hardware metric screws
I’m working on getting this bandsaw a budy gave me working and I came accross an interesting snag. The screws on it are all metric (of course). But the funny thing is, the ones that I don’t have enough of are M6 with 1.25 threads. As far as I can tell, this aren’t really made much any more. That is, I can’t find them at Lowes or Ace Westlake.
So, I figure if I do some looking I could probably find an M6 with 1.25 threads somewhere. But just in case, I’m looking into a plan ‘B’.
I just read in Shop Notes and they opened my eyes to a wonderful tool called the Tap and Dye. I seriously never new that this was what this tool was for. Dumb me, huh?
So, I’m considering getting a small set and using the tap to re-bore some of the holes to accept a slightly bigger screw (maybe something that isn’t metric). But, I wanted to get some input first. The part that I am going to be tapping is the table for the saw on the underside.
Anyone think this will work? Is there anyone who has some tips on when I do this? Any other optoins other than Plan ‘A’ and Plan ‘B’ that I haven’t thought of?
Thanks.
Danny Boy
-- He said wood...http://hickbyassociation.blogspot.com/
View oldskoolmodder's profile
oldskoolmodder
707 posts in 573 days
175 days ago
LOCAL hardware stores almost always carry these, at least around me they do. Sometimes the locals can be your friends.
View DaleM's profile
DaleM
402 posts in 277 days
175 days ago
A tap and die set should work fine. When using it, make sure you don’t try to cut too much at once. Repeatedly back the tap back up to remove waste, then thread it back in to cut some more. If you try to do too much at once and snap it off in the hole, it will be really, really hard to remove as it is necessarily very hard steel and you will end up with a bigger problem than you started with. (Or so I heard, not that I would do something like that)
-- Dale Manning, Carthage, NY
View TopamaxSurvivor's profile (online now)
TopamaxSurvivor
3013 posts in 569 days
175 days ago
Be sure to use the right size drill first, use something like “Tap-eze” or cutting oil, and back the tap out every little bit to clear it. They are very hard and a bit brittle to cut hard steel, they break fairly easily if forced too much.
View lew's profile
lew
4481 posts in 648 days
175 days ago
Also, you may need to expand your twist drill bit set. Depending on the size of the tap, you may need some “odd” sized drill bits that are not so common in wood working. Sizes up to 1/4” are often “lettered” sizes.
To get a good “fit” you need to use the precise size bit. It may be cheaper to buy what you need rather than a set. In fact, if all you are doing is tapping holes, you probably won’t need the die and die handle- which can be expensive. Get the tap, tap handle and the bit to match the “percentage” of thread depth. Look up the Starrett site for a machinist chart. It will give you everything you need.
Sorry- Topamax beat me to some of this!
View marcb's profile
marcb
696 posts in 566 days
175 days ago
Metric taps use metric drill bit sizes.
DannyBoy
174 days ago
Oldskool, You’d think I’d find it, but I went to three different hardware stores and didn’t. The 1.25 threads are widely available for M7s and M8s but not for M6s. There in lies my problem.
I’ve got enough to hold everything together, but I’m going to want to finish it out so I’ll probably be upgrading my tool set to have the at least the taps for this. I appreciate the helping advice, guys!
Danny
View Mike's profile
Mike
267 posts in 510 days
170 days ago
Sometimes I find the closest reg threaded self tapping screw. It works I use that to redo the threads then use a screw with the same threads without the tapping front.
Do it all the time on metal doors and frames. Aluminum doors, even safe doors. And those are thick.
Saves me from redrill and tapping.
-- Measure once cut twice....oh wait....ooops.
