| Forum topic by DocK | posted 181 days ago | 603 views | 0 times favorited | 6 replies | ![]() |
181 days ago |
Topic tags/keywords: question |
181 days ago |
Oil on wood for outdoor projects is always good but you will need to reapply it every few years. BLO will act as a water repellent but won’t last forever. Also BLO alone has no UV inhibitors so don’t be surprised if it still goes gray after some time. Your best bet really is a natural oil stain, which has oil in it, uv inhibitors and some pigment (which also aids with uv ) but which also enhances the natural color – that is, if you want to retain that natural wood color. Good luck and post some pics when you are done! -- Steve, New Zealand, www.steveracz.com |
181 days ago |
You might also think about tung oil, if you just want an oil finish. I think it will hold up better to the weather, but like Steve said, you’ll have to reapply it every year or so. -- Tim -- http://tmuli.com |
181 days ago |
Thanks for the info! -- DocK |
181 days ago |
DocK: Real Tung Oil, not “TUNG OIL FINISH” has been used for centuries in Asia for outdoor wood including boats. Real Tung Oil: Tung Oil is best applied “fat over lean.” Start by diluting Tung Oil 1:1 with mineral spirits. Use this as your initial treatment. Let it soak in then wipe off the excess after about 30 minutes. Allow it to dry for about 2 or 3 days, then rub on thin coats of full strength Tung Oil. Repeat for about 3 to 5 thin coats, allowing each coat to dry for about 2 days. You might want to consider using a good spar (marine) varnish. Especially, one made with Tung Oil (e.g. WaterLox, Epifanes, etc.) For UV protection, you might want to consider Sikkens Cetol. Be willing to experiment. -- Randy, Rustic Artisan, a family tradition. (No PM's - auto-deleted.) - "I am a seeker, not a follower." |
181 days ago |
Hey Dock -- Jim from Heirloom Woodshop, custom furniture ,maker, woodworking school, heirloomwoodshop.com |
180 days ago |
Ask and thee will be answered. Good one from all of you. Many Thanks. -- DocK |
| Forum | Topics |
Woodworking Skill Share
2925 |
3959 |
258 |
954 |
225 |
Woodworking Trade & Swap
622 |
Coffee Lounge
2398 |
LumberJocks.com Site Feedback
524 |
