Outfeed table design--why not a grid?
Forum topic by wildbill001 posted 03-05-2015 11:23 PM 1353 views 0 times favorited 16 replies Add to Favorites Watch
View wildbill001's profile
wildbill001
111 posts in 2608 days
03-05-2015 11:23 PM
Topic tags/keywords: tablesaw outfeed
I need to add an outfeed table to my R4512. Every outfeed table I have seen so far is usually a solid top with slots that act as extensions for the miter-gauge slots. My question is why not use a grid instead (think lattice work)?
Seems like a grid would be lighter putting less stress on the back rail of the saw as well as less likely to make the saw more difficult to roll around. And I need to be able to move my saw around to allow SWMBO’s car into the garage.
Am I missing something or some reason why a grid would be a bad idea for an outfeed table?
TIA
Bill W.
-- "You can tell the pioneers by the arrows in their back" -- Unknown
16 replies so far
View Garbanzolasvegas's profile
Garbanzolasvegas
356 posts in 1192 days
#1 posted 03-05-2015 11:29 PM
I built a simple assembly table with 2×6 that have a 1 inch gap between them so I could get clamps down between them for glue ups and assembly. Found out just by accident its a hair shorter than the top of my TB table, so when I need an out feed table I just push it up to the out feed area of my TS ….. WAL LA!
-- If you don't Play, you can't win
View Mykos's profile
Mykos
103 posts in 1760 days
#2 posted 03-05-2015 11:32 PM
A solid table will work with any sized piece coming off. A grid will have gaps that stock can fall in or get hung up on. If that happens during the middle of cut it’s bad news.
View TheFridge's profile
TheFridge
9249 posts in 1451 days
#3 posted 03-05-2015 11:44 PM
What he said
View JeffP's profile
JeffP
573 posts in 1357 days
#4 posted 03-06-2015 01:14 AM
Maybe a compromise between solid and “grid”...
https://www.youtube.com/watch?v=6K81qQofCeM
He made what he calls a “torsion box”. Basically two relatively thin sheets around a “grid” of thin support pieces.
You could also consider a pre-made one of these kind of table tops in the form of an interior grade door repurposed as a table-top. It would be light weight but stiff and strong and would not have any holes that wood can drop into.
-- Last week I finally got my $*i# together. Unfortunately, it was in my shop, so I will probably never find it again.
View Tugboater78's profile
Tugboater78
2740 posts in 2157 days
#5 posted 03-06-2015 01:24 AM
How bout something like mike mertze made
https://m.youtube.com/#/watch?v=5esk9dgCzCQ
Based on Ron paulks workbench.
-- "....put that handsaw to work and make it earn its keep. - summerfi" <==< JuStiN >==>=->
View MT_Stringer's profile
MT_Stringer
3160 posts in 3196 days
#6 posted 03-06-2015 02:08 AM
When I use my planer, the boards will hang up on anything that is not dead flat and smooth. I would expect the same thing if you had a grid and the board was ever so slightly bowed downward when ripped on the table saw.
I wouldn’t do it.
My table does have clamp tracks in it but they run parallel to the boards and haven’t presented any problems.
wildbill001
#7 posted 03-06-2015 05:53 PM
I understand about the risk of material catching as it comes off the saw. But I see so many table-saws with grid-like wings that I thought that might work for the outfeed.
The idea of the torsion box is a good one although I don’t think I need to go to the level of detail that Mike Mertze went to.
Ok, so maybe back to the drawing board.
Thanks folks!
View Ghidrah's profile
Ghidrah
667 posts in 1188 days
#8 posted 03-06-2015 06:41 PM
The hgt of my work bench is the same as the TS the bench is 30” X 80” and had wheels at one end.
-- I meant to do that!
View Earlextech's profile
Earlextech
1160 posts in 2656 days
#9 posted 03-06-2015 07:22 PM
My out-feed is a torsion box, built 30 years ago! It makes my table saw size overall – 6’ x 10’. I made the outside corner perfectly square to easily square up anything I need. Covered with white laminate that I might change out finally this year! It’s my workbench, assembly table, table saw all together.
View Ocelot's profile
Ocelot
1956 posts in 2604 days
#10 posted 03-06-2015 08:28 PM
I think you could make something with a solid part in line with the blade and a grid farther to the left and right. Then, small stuff wouldn’t fall through or get hung up, and large stuff could slide fine on the grid. You could even make the parts of the grid in-line with the motion of the boards a trifle higher than the cross pieces – which basicly are only for structure.
... but, a torsion box with thin skin would be stiffer…
-Paul
MT_Stringer
#11 posted 03-06-2015 09:22 PM
If I didn’t already have a good strong frame for my bench, I would make a table like Ron Paulk. I bought his plans for reference and used the idea on my miter saw station. Sometimes it is nice to have those holes available, sometimes not because they are in the wrong spot! :-)
My current work surface is a outfeed table, assembly table and anything else I need it for including clamping and gluing.
My worktable
http://lumberjocks.com/projects/68635
Mobile Workstation. (Two thumbs u for this one!)
http://lumberjocks.com/projects/92907
Adjustable Height Work Table/Dual Router Station (Four Thumbs up!)
http://lumberjocks.com/projects/101964
Miter Saw Station (There are several blog entries on building the miter saw station…at least four.)
http://lumberjocks.com/MT_Stringer/blog/36618
View Woodknack's profile
Woodknack
11478 posts in 2345 days
#12 posted 03-06-2015 10:52 PM
I don’t have a picture but my outfeed is similar to a ladder except square and uses pvc spaced several inches apart. The pipe is cut in half and fixed to the “rungs”. The rounded edges prevent boards from getting stuck and pvc is very slick. It works great for my purposes.
Tugboater78
#13 posted 03-07-2015 12:49 AM
Mike, thanks for posting links to your mitersaw blog. I remember when you first started it, it caught my interest cause i was thinking of a similar setup, but couldnt follow at the time and slipped my mind.
View DaveHuber's profile
DaveHuber
47 posts in 3083 days
#14 posted 03-07-2015 01:10 AM
The grid presents a very good opportunity to pinch your fingers between work sliding across it and the grid.
DAMHIK
Nasty
-- Dave, Oak Park, IL
View redryder's profile
redryder
2393 posts in 3067 days
#15 posted 03-07-2015 05:52 AM
I have this outfeed roller system on my saw and love it.
Put it up or put it down. Great space saver when needed….....................
-- mike...............
