Staining corners
Forum topic by Gustoid posted 05-29-2009 03:22 PM 1137 views 0 times favorited 3 replies Add to Favorites Watch
View Gustoid's profile
10 posts in 3237 days
05-29-2009 03:22 PM
Topic tags/keywords: question
I recently made a serving tray, and to avoid getting dark spots in the corners, I stained it before I glued it together. However, I realized after it was glued that I wanted to sand the joints to improve the look. With it already being stained I decided not to sand it. My question is, how can I stain it after I glue it, without getting dark spots where the corners meet the bottom of the tray? I stained a drawer not long ago and I was not able to wipe all the stain from the corners, and I ended up with dark spots.
-- Gustoid
3 replies so far
16273 posts in 4152 days
#1 posted 05-29-2009 03:35 PM
Try using a small, cheap foam brush to wipe excess stain from the corners.
117032 posts in 3511 days
#2 posted 05-30-2009 03:28 AM
Depends on the wood and stain. but in general use charlies tip
-- wood crafting & classes
View RBWoodworker's profile
441 posts in 3286 days
#3 posted 05-30-2009 05:54 PM
Charlies tip for sure..or if you want.. take a scrap piece of wood about 1/2” wide.. cut a sharp taper to it so it looks kind of like a wedge or a shim.. put a rag over it and slide it along the joint to wipe off the excess.. or..
just blow it out with an airhose and a blast of air..all these ways work good for me..
-- Randall Child
