Butt jointing a walnut and ash end table top.
« back to Joinery forum
Forum topic by SG6578 posted 03-04-2015 11:53 PM 1209 views 0 times favorited 12 replies Add to Favorites Watch
View SG6578's profile
SG6578
42 posts in 1119 days
03-04-2015 11:53 PM
Topic tags/keywords: butt joining table top laminating laminate cutting board butcher block workbench
Hello all,
I am working on a laminated table top made from walnut and ash. Pieces are 7/8” thick x 1 1/2” wide x 24 1/2” long.
Aiming for 24×24 x 1 1/2” thick. after some squaring and sanding.
It will be fastened exactly as it sits in the picture. It’s just clamped for now with no adhesive.
Because the pieces were planed and not ran over a jointer to straighten them out some have a 1/8”+ bow in the length causing gaps.
My plan is to drill through the center of all of them in three places (ends and middle) and run a 1/4-20 threaded stainless rod through and glue them up. I would counterbore the second piece in on both sides to clear the nuts that would thread onto the rod. Much like a compression system on log cabin walls.
Good plan or not? I am under the impression that gluing warped pieces together is a bad idea unless you have some form of constant outside tension which in this case would be provided by the tightened rod.
12 replies so far
View Greg In Maryland's profile
Greg In Maryland
553 posts in 2906 days
#1 posted 03-05-2015 12:03 AM
I would not run a rod through them. Too much work for too little benefit. Besides, you will never get a smooth and level surface this way. Instead just glue up as you normally would and plan on flattening the top. You may lose a little bit of thickness, but no more than the largest ‘gap.’ Do you have access to a drum sander? A drum sander will make short work of flattening to top.
Good Luck!
Greg
View AandCstyle's profile
AandCstyle
2977 posts in 2165 days
#2 posted 03-05-2015 12:05 AM
SG, the wood WILL move in spite of the steel rod and somewhere, somehow cracks will develop. Also, I think it would be very difficult to drill straight lines through that many pieces for the rod to go through unless you drill them over sized. Why not just plane the bowed pieces straight and glue them? Maybe I am missing something. :)
-- Art
View buck_cpa's profile
buck_cpa
150 posts in 1795 days
#3 posted 03-05-2015 12:12 AM
i’d pipe clamp and glue that mother. I’ve found that if you’re strategic with your warped pieces they can add structural integrity… much like a spring joint.
easy on the gd on the signature line brother… could be considered offensive where I come from.
SG6578
#4 posted 03-05-2015 12:13 AM
I have a friend with a 36” drum sander. I also have access to a knee mill with a cnc readout so the drilling wouldn’t be that much more work. 1/4-20 thread usually receives a 9/32 clearance hole.
My concern a and c is losing thickness in the pieces causing a non-symmetrical appearance. My specific planer also leaves moderate snipe which would have to come out. Correct me if I’m wrong but a planer is used most for achieving desired thickness, not flattening boards. I was under the impression that a jointer is the tool I would need to take out considerate bows in the pieces.
Not being a smartass, this is all mostly new to me.
Busch light could be considered offensive where I’m from. XD
buck_cpa
#5 posted 03-05-2015 12:34 AM
well played. like most woodworkers, i’m cheap!
View Mark Davisson's profile
Mark Davisson
597 posts in 3225 days
#6 posted 03-05-2015 12:43 AM
You’re describing the method I used to create the laminated top for my workbench. I drilled (carefully) the holes (slightly oversized) prior to glue up. I used the all thread (3) as clamps in addition to several pipe clamps. Flattening was still required. I’m happy with the results.
-- I'm selfless because it feels so good!
SG6578
#7 posted 03-05-2015 12:49 AM
How thick was your bench and what size thread did you use?
I’m thinking 1/4-20 will be strong enough without drilling a hole so large that it causes weak areas in table.
View gfadvm's profile
gfadvm
14940 posts in 2598 days
#8 posted 03-05-2015 12:50 AM
I think this will work. I glued up a king sized headboard from strips before I had a jointer and I screwed the pieces together as I glued them. There has been no warping or cracking over 5 years.Click for details
Mark Davisson
#9 posted 03-05-2015 12:56 AM
SG, the top is 3” thick. 24” wide. And the all thread is 1/4” rod, but I can’t tell you the thread count – don’t remember.
SG6578
#10 posted 03-05-2015 12:58 AM
Very nicely done and thanks for the feedback gfadvm. I have seen projects in the past with using just glue and some have splitting problems so I think I’m going to try the threaded rod out.
SG6578
#11 posted 03-05-2015 01:03 AM
Thanks Mark, Buck, Art, and Greg for the help as well. I’m going to go with either a 1/4-20 or 10-24 threaded rod and will hopefully post some pictures of the process.
My intention with the rod is simply to provide constant pressure after the glue has set -preventing splits along the glue joints. I will flatten with my friend’s drum sander after it has dried a while and square it up.
View TheFridge's profile
TheFridge
8901 posts in 1394 days
#12 posted 03-05-2015 01:13 AM
A drill press with a home made table and stops will make drilling holes easy easy.
