Re-boring holes
Forum topic by ralmand posted 05-29-2009 12:57 AM 1072 views 0 times favorited 6 replies Add to Favorites Watch
View ralmand's profile
162 posts in 3235 days
05-29-2009 12:57 AM
Topic tags/keywords: holes rebore re-bore drilling
I am looking for suggestions on re-boring 5/8” holes to 3/4” holes with a 5 degree angle in a work top. I cannot use the drill press…I need to use a portable drill. Any suggestions or assistance would be GREATLY appreciated.
-- Randy, Allen Texas
117030 posts in 3510 days
#1 posted 05-29-2009 01:04 AM
Hey Randy
there are a couple of ways you can re drill, you can plug the 5/8 hole with a dowel cut it off and redrill,
You can put a small piece of 1/4 ply or any wood over the hole with double sided tape drill a very small hole in the middle from the back or have an x on the small piece so it is centered. or borrow or buy a step drill bit that has several sizes on one drill bit. the 5 degree part can be done buy setting a t bevel or angle gauge to 5 degrees and holding your tbevel next to were your drilling and drill using you bevel as a line of site. It still would be more acurate if it could be done on a drill press by tilting the table 5 degrees.
-- wood crafting & classes
#2 posted 05-29-2009 01:09 AM
Hey Jim…How are you? Thanks for the advice
View davidroberts's profile
1027 posts in 3418 days
#3 posted 05-29-2009 01:13 AM
are you installing bench dogs? you may could just go up in bit size 1/16 at a time, slowly, or maybe use a forstner bit. i use a portable drill guide
on either jig, you can apply a few pieces of tape to one side until it leans 5 degrees. forstner would be cleaner i suppose.
-- Better woodworking through old hand tools.
#4 posted 05-29-2009 01:15 AM
Yes I am…The portable drill guide is what I was thinking, but I wanted some expert opinions before proceeding. Thanks!
View CutNRun's profile
122 posts in 3779 days
#5 posted 05-29-2009 01:27 AM
Do you have access to a drill press? Could you bore the correct diameter hole in a wood block at the correct angle and then use this as a guide for drilling your bench dog holes? Just a thought.
-- CutNRun - So much wood, so many trails, so little time
#6 posted 05-29-2009 01:33 AM
Yes I have a drill press…GREAT idea. This is why I LOVE this website! So many friendly people willing to share their knowledge. Thanks!
