Edge Glued Joint - Glue Melted w/ Branding Iron?
« back to Joinery forum
Forum topic by Keith Kelly posted 03-04-2015 07:54 PM 778 views 0 times favorited 1 reply Add to Favorites Watch
View Keith Kelly's profile
Keith Kelly
263 posts in 1662 days
03-04-2015 07:54 PM
I’m working on making a branding iron, and I pulled out a cutoff glue-up of Walnut & Cherry to test the branding iron on. I would have used Titebond, but I’m not sure if it was I/II/III as I made this as a test piece several months ago.
Problem: When I branded across the glue joint, a gap appeared between the walnut & cherry. It’s small, but large enough to put a utility knife blade into. I tested a few more times, and sure enough, a gap appears when branding across a joint.
Now, the easy solution is to avoid branding across 2 woods. But, I wouldn’t have imagined this being a problem, so I’m curious if it’s my branding technique or a problem with my joint. Perhaps I need to get the branding iron way hotter, so it doesn’t have to sit on the wood as long.
Any ideas?
-- Keith - Bolivar, Missouri, http://www.SquareOneWoodworks.com
1 reply so far
View SirIrb's profile
SirIrb
1239 posts in 1229 days
#1 posted 03-04-2015 08:02 PM
Its the heat. A gent posted a table he made to hold his laptop on LJ a few days back. the exhaust blowing on the table top caused a slight gap. Brand on a single board.
