Biscuit Joiner Spacing
Forum topic by Garbanzolasvegas posted 03-04-2015 01:20 PM 2088 views 0 times favorited 8 replies Add to Favorites Watch
View Garbanzolasvegas's profile
Garbanzolasvegas
356 posts in 1096 days
03-04-2015 01:20 PM
When making solid wood panels using biscuits how far apart should one space the biscuits?
-- If you don't Play, you can't win
8 replies so far
4820 posts in 2363 days
#1 posted 03-04-2015 01:35 PM
I use them for alignment, and really don’t have a set spacing. I guess at how many biscuits I want (maybe 5 across 60”) and then space them more or less evenly. If you have an edge that will be cut, you’ll want to not put any on the cut line (Doh!). The other thing you want to do is put them in the lower 2/3s of the board edge to help with the football shape that may telegraph through the surface if you’re not careful. If both sides of the board panels will be seen, then perfectly centered on the edge might be a better option.
View Ghidrah's profile
Ghidrah
667 posts in 1092 days
#2 posted 03-05-2015 01:35 AM
For me it also depends on the thickness of the board. The greater the crown the closer I put them, I never went closer than 6” spacing. I also glue them into their slots, all possible effort to keep junk together.
-- I meant to do that!
View TheFridge's profile
TheFridge
8634 posts in 1355 days
#3 posted 03-05-2015 01:55 AM
What he said
View MT_Stringer's profile
MT_Stringer
3133 posts in 3100 days
#4 posted 03-05-2015 02:55 AM
I don’t use anything but glue and clamps.
17193 posts in 1726 days
#5 posted 03-05-2015 03:11 AM
I do about 12”. I don’t measure.
View pjones46's profile
pjones46
997 posts in 2512 days
#6 posted 03-05-2015 03:15 AM
Just be careful to plan the spacing so you do not cut into them on the finshed panel and expose them.
-- Respectfully, Paul
View Picklehead's profile
Picklehead
1041 posts in 1799 days
#7 posted 03-05-2015 03:25 AM
So far the average space between my biscuits is about two years.
-- You've got to be smarter than the tree.
Ghidrah
#8 posted 03-05-2015 03:44 AM
I did a similar screw up about 15yrs ago on a set of doors for a vanity. I ran a mahogany spline too long along the length of re-sawn panel boards then when I ran them through the router table for the panel cuts I exposed the mahogany splines. These re-sawed panels had beautiful medullary figuring and they were wrecked. Until the owner saw the mistake and liked the contrasting color, go figure. By the time I was done I ended up applying swirly oak string inlay to the doors.
