Pine dinning table project (I'm new). Started to sand but need to strip?
Forum topic by mattme posted 03-04-2015 04:03 AM 684 views 0 times favorited 4 replies Add to Favorites Watch
View mattme's profile
mattme
4 posts in 1145 days
03-04-2015 04:03 AM
Hey all,
I’ve got a dining table that is made out of pine with some type of finish on it. I wanted to resurface it but the finish on the table keeps clogging up my sand paper as I sand. At this point I am thinking of stripping the remaining finish off of the table. Should I do this? If so what type of stripping solution should I use? Is it safe on areas that I’ve already sanded?
View mahdee's profile
mahdee
3870 posts in 1732 days
#1 posted 03-04-2015 04:04 AM
More likely it was finished with lacquer. Try lacquer thinner.
-- earthartandfoods.com
View sawdust703's profile
sawdust703
270 posts in 1385 days
#2 posted 03-06-2015 01:43 AM
If you have sanded to bare wood in spots, you can use blue painters tape, & tape those spots off if its a worry to you. Home Depot has a stripper that comes in a tub container. Works great. Like any strip job, there is always going to be some labor involved.
-- Sawdust703
View TheFridge's profile
TheFridge
9249 posts in 1451 days
#3 posted 03-06-2015 01:47 AM
Stripper shouldn’t hurt the wood. Just wipe the wood down with mineral spirits when done to get any residue off.
View tomsteve's profile
tomsteve
771 posts in 1184 days
#4 posted 03-06-2015 01:52 AM
What grit and what brand of sandpaper are you using?
