Brad Nailer vs. Pin Nailer on 1/4 material
Forum topic by BrandonR posted 03-04-2015 03:32 AM 1248 views 0 times favorited 11 replies Add to Favorites Watch
View BrandonR's profile
BrandonR
64 posts in 2262 days
03-04-2015 03:32 AM
I just got a request to make some small boxes for a client. He wants me to use 1/4 solid poplar or oak to make the boxes… He wants them really simple with just but joints and glues and nailed…. I have never worked with this thin of material with brad nailer… I had a lot of problem with the nails shoot out the sides or splitting the wood….
would you suggest a pin nailer, and would it hold pretty good with glue? Or am I using the brad nailer wrong? What size nails would you recommend?
Thanks!
11 replies so far
View johnstoneb's profile
johnstoneb
2871 posts in 2141 days
#1 posted 03-04-2015 03:51 AM
Glue should hold just fine. I use pins in that size material but only to keep it from shifting when clamping. I have had problems with pins over 1/2 ” long coming out the side. You stand a good chance of splitting the material with a 18 ga brad nailer.
-- Bruce, Boise, ID
View jumbojack's profile
jumbojack
1674 posts in 2593 days
#2 posted 03-04-2015 03:57 AM
The trick.with mailers it to orient the nailer on the same like as the material. If you run perpendicular the nail hits a hard spot the chisel point directs the nail out or through your work. With 1/4” material I suggest a pin nails and glue.
View woodchuckerNJ's profile
woodchuckerNJ
1269 posts in 1603 days
#3 posted 03-04-2015 04:01 AM
Glue would hold alone, the only reason for nails is to avoid clamping.
if you have enough clamps just glue.
If not a pin nailer for 1/4 would work, but I would rather just clamp, or gang clamp.
-- Jeff NJ
View NoThanks's profile
NoThanks
798 posts in 1498 days
#4 posted 03-04-2015 05:00 AM
Iwud just cut a rabbit and dado and glue them.
-- Because I'm gone, that's why!
View ChefHDAN's profile
ChefHDAN
1057 posts in 2818 days
#5 posted 03-04-2015 12:31 PM
+ to Iwud4u, with 1/4” it’s real easy to just run quick 1/8” dados then sneak up on the rabbet/tenon
BrandonR
#6 posted 03-04-2015 12:39 PM
Thanks! I will be making a great quantity of these, so try to figure out most efficient method.
Would you suggest doing the dados on the table saw or router for just 1/8th. I don’t have dado blades on my table saw, so would need to make multiple passes.
Thanks
View PaulHWood's profile
PaulHWood
432 posts in 2221 days
#7 posted 03-04-2015 01:47 PM
agree minimum length pin to just hold while you clamp, even in oak, they will deflect
-- -Paul, South Carolina Structural Engineer by trade, Crappy Woodworker by choice
NoThanks
#8 posted 03-04-2015 02:38 PM
I’d do it on the table saw myself.
Regular 1/8” kerf saw blade would work fine, even a thin kerf blade as long as you match the tenon to the kerf.
Just make sure your blade leaves a flat bottom.
BrandonR
#9 posted 03-04-2015 03:26 PM
Thanks guys! Here is the box… Only diffrence is that front plate will go up past the sides before it takes the angle.
BrandonR
#10 posted 03-04-2015 03:27 PM
Should I do the same joinery with the bottom piece, or will that mess up when it 3 sides meet in a corner. Sorry for all questions, I rarely do joinery…
View gfadvm's profile
gfadvm
14940 posts in 2659 days
#11 posted 03-05-2015 01:30 AM
You said he wants butt joints but this project is a perfect candidate for box joints with a dado for the bottom.
