Eletrical question related to charging a tablet
« back to Coffee Lounge forum
Forum topic by InstantSiv posted 03-04-2015 01:17 AM 1015 views 0 times favorited 4 replies Add to Favorites Watch
View InstantSiv's profile
InstantSiv
262 posts in 1832 days
03-04-2015 01:17 AM
Topic tags/keywords: question
Hi all. I have a question…
I recently got one those new power bank/car jumper, Highly recommended btw (car battery died during the recent snow storms and I jumped my car 7 times on 1 charge, still showed 80% charge. It allowed me to wait until the weekend to get a new battery on my normal errand run), anyways… I got a charging cord for my tablet. The tablet charger’s output is 2.58 amps and the output on the power bank is 2.1 amps.
The question is is a difference in amps going to harm the battery or is it just going to charge slower?
View English's profile
English
660 posts in 1714 days
#1 posted 03-04-2015 09:16 PM
Yes it will just charge slower. The table may try to draw more , but most power supplies these days use a clamping circuit that will reduce the voltage to keep the current with in it’s max range.
I am assuming that you are going to plug the tablet into a USB port on the power bank.
-- John, Suffolk Virgina
InstantSiv
#2 posted 03-04-2015 09:41 PM
Hi English thanks for the reply.
No USB, I don’t know what the plug is called… here’s a link http://www.amazon.com/520X-M-Magnetic-Charging-Microsoft-charging/dp/B00OTD2606/ref=sr_1_4?ie=UTF8&qid=1425504880&sr=8-4&keywords=surface+pro+3+power+adapter+cord+plug
edit
Output is a DC plug 5.5×2.1mm
19610 posts in 2094 days
#3 posted 03-04-2015 09:46 PM
Some will charge slower and the phone may actually tell you, but some like my new Samsung won’t charge at all if there isn’t enough power.
InstantSiv
#4 posted 03-05-2015 05:28 PM
2 Updates.
I read the amps incorrectly… DUH!
1. USB output is 2.1 amps. Since I’m using a DC plug the output is 2.5 amps.
2. I charged the tablet but something went wrong. Full charge on the battery bank and the tablet at about 20%. After an hour or 2 The battery bank was completely dead and the tablet was at about 75-80%. USB port was also non-functioning. I restarted the tablet and it went through a Windows update. USB ports work again.
Either there’s an issue charging the tablet with the battery bank or the windows update screwed something up. I am going to try and charge it again so I’ll post what happens.
