Planing MDF?
Forum topic by juniorjock posted 185 days ago 472 views 0 times favorited 11 replies Add to Favorites Watch
View juniorjock's profile (online now)
juniorjock
790 posts in 664 days
185 days ago
Topic tags/keywords: planing mdf with dw 735
I’m sure this has been asked and answered before but I searched the site and couldn’t find the it. I have some 3/4” MDF that is slightly thicker than what I need it for. My question is: Is it ok to run the MDF through my DW 735? I’m thinking that the glue in the MDF may be a little too hard on the blades. Thanks in advance.
-- JJ...... I guess you could say I'm a 54 year old "juniorjock". — Make things with wood.
View hootr's profile
hootr
133 posts in 245 days
185 days ago
i haven’t tried it either but i think if you slow the feed rate way down and take baby bites it would work
-- Ron, Missouri
7675 posts in 1117 days
185 days ago
I don’t work with it much myself, but I hear that it is really tough on saw blades, so I would think it would be hard on planer blades as well.
View GaryK's profile
GaryK
9539 posts in 887 days
185 days ago
Say goodbye to your sharp blades if you do it.
View turkva's profile
turkva
24 posts in 844 days
185 days ago
I have done it twice now, I had to reduce the thickness of a couple of door panels by about 1/16”. I have a Delta 13” planer and set it for 1/32” cuts at the slower feed rate. Worked fine. I did put in a set of used knives as I thinking it would dull my new knives. The panels came out nice and smooth, but not as smooth as the original surface. And it will suck up the paint also since you are opening up the “grain” of the wood. It didn’t seem to hurt the knives too much, but I would suggest using older knives if you have them.
Hope this helps.
-- Accept Nothing, Challenge Everything
View RedShirt013's profile
RedShirt013
118 posts in 560 days
185 days ago
The adhesive will dull any HSS steel blades quickly. Plus some MDF is not consistent in density surface vs core, so if you’re not laying up the veneer/plam shortly after and it’s not balanced and MC changes it might not be flat anymore.
-- Ed
View Damian Penney's profile
Damian Penney
1030 posts in 890 days
185 days ago
I’ve done it and it works fine, I get so little shop time that blade dulling isn’t much of a problem :)
View jeffss's profile
jeffss
3 posts in 185 days
185 days ago
mdf is an extruded product and as such can have any-thing in it. i work at Marc Adams School of woodworking, and a student brought in a sheet of OSB ( ie wafer board) with a wire bristle brush (1/2 sanded away) embedded in it. from the other side it looked perfectly normal. other instructors have found stones or BOLTS in their MDF. I would run it through a drum sander before planing it, personally.
View BarryW's profile
BarryW
872 posts in 805 days
185 days ago
nope…not in my book
-- /\/\/\ BarryW /\/\/\ Stay so busy you don't have time to die.
View socalwood's profile
socalwood
968 posts in 503 days
185 days ago
I plane it all the time -
View kimball's profile
kimball
51 posts in 196 days
184 days ago
I’ll tell you this, MDF is extreemly hard on the carbide on saw blades….. so…. to extrapolate that to the blades on a thickness which are made of HSS and have at least 96 times more cutting surface…....
View doyoulikegumwood's profile
doyoulikegumwood
278 posts in 891 days
184 days ago
i’ve planed this stuff befor the only thing i would say is add an inch all the way around each peice your sending thru the planer ive found i get some chip out on the edges.
-- I buy tools so i can make more money,so ican buy more tools so I can work more, to make more money, so I can buy more tool, so I can work more
