Router bits
Forum topic by woodman71 posted 05-27-2009 02:28 AM 788 views 0 times favorited 3 replies Add to Favorites Watch
View woodman71's profile
162 posts in 3257 days
05-27-2009 02:28 AM
Hello everyone I had a problem with my shed doors they are five years old and made out pine.There are made using stile and rails construction and the doors are 1inch quarter thick and here the problem i ran into most stile and rails bit work in 3/4 thick and I look at door entry door bit but they work in 1 3/8 and up not lower so i was able to build the doors but i used a bit for 3/4 thick just had to modify the bit it was a reversible bit so i was able to make changes but does anyone know were you can find these bit that work in thickness of 1inch to 1 1/4 i cant find any online been to cmt,freud and some others i guess you could say why are you looking you got the doors built yes but i want to know for future reference thanks
3 replies so far
View cabinetmaster's profile
10874 posts in 3491 days
#1 posted 05-27-2009 02:36 AM
Freud has a set for extrior doors that advertise in all the woodworking magazines. Look it up on Freud’s website.
117030 posts in 3510 days
#2 posted 05-27-2009 02:42 AM
It seems like I’ve seen a set on e bay. Sometimes you can adjust the cut buy changing bearing sizes
-- wood crafting & classes
View FEDSAWDAVE's profile
293 posts in 3365 days
#3 posted 05-27-2009 03:33 AM
That’s not Freud’s web site cabinetmaster.
Neither is this: but, it’s authorized
As a matter of fact, make sure when buying a Freud tool that you’re buying from an authorized distributor so you’re getting genuine Freud Tools!
-- David,
