Recommend a finish for bathroom barn wood mirrors.
Forum topic by Paul Maurer posted 03-03-2015 05:09 PM 807 views 0 times favorited 9 replies Add to Favorites Watch
View Paul Maurer's profile
Paul Maurer
162 posts in 1548 days
03-03-2015 05:09 PM
I am to make bathroom mirrors out of barn wood. It has been suggested to use spar varnish. I don’t think so and have suggested making samples to choose from. Help me determine what to sample with your suggestions please.
9 replies so far
View Bill White's profile
Bill White
4928 posts in 3954 days
#1 posted 03-03-2015 05:36 PM
Not enough info as to what you’re trying to achieve. Gloss, semi gloss, satin, flat sheen? Rough primitive surface?
Give us a bit more to work with.
Bill
-- bill@magraphics.us
View Kelly's profile
Kelly
2025 posts in 2938 days
#2 posted 03-03-2015 06:30 PM
Generally, driftwood or barnwood will take on a golden amber look when you apply oil or oil based poly. It’s a nice effect, but, obviously, the gray turns.
I’ve had good luck keeping the original look with lacquer, but I had to mist the first coat, or three, so it rested on the surface and dried, rather than soaked in.
I haven’t tried the waterborne finishes. They might be worth a shot.
In the end and once you get the surface sealed, anything should be fair game. As long as you keep the wet off, it should be fine.
If you want to crank up the protection against shifting due to humidity changes, consider sealing every side and edge. However, unless your bath is a sauna or like one, running a fan will go a long ways to eliminating unwanted, damaging moisture. Too, the little amount that is going to work its way into the wood from the back should be minimal.
View Yonak's profile
Yonak
986 posts in 1515 days
#3 posted 03-03-2015 08:13 PM
What’s your purpose for the finish ? It seems to me, if you’re going for the rustic look, do you want a finish ?
Paul Maurer
#4 posted 03-04-2015 06:25 PM
The barn wood is very weathered and worn. Its texture is rough with about 3/16 variation. Its surface must be kept in this condition. As for the type of finish – I am leaving that up to the customer. I am looking for experienced opinions, so that I don’t overlook an option to sample for the customers selection.
I am in favor of no finish or an oil. However the customer was sold spar varnish and is concerned about the moisture in the bathroom.
View mcg1990's profile
mcg1990
159 posts in 1286 days
#5 posted 03-05-2015 12:47 AM
I haven’t experimented a whole lot, but I found using my Wagner Plus sprayer (Walmart $100 cheapy) and putting Matte Ploycrilic looked pretty good.
I hate Spar varnish and hope to never use them again.
View canadianchips's profile
canadianchips
2600 posts in 2991 days
#6 posted 03-05-2015 01:06 AM
Minwax satin “Polycrylic”. It is water based, leaves the wood the color it is, wont yellow.
Thin coats, if you can spray it better yet.
View gfadvm's profile
gfadvm
14940 posts in 2684 days
#7 posted 03-05-2015 01:37 AM
I love Spar urethane! I have sprayed it on a lot of rustic and live edge projects. It will add some color/darken the wood but would be a good choice in a bathroom environment.
View TimberMagic's profile
TimberMagic
114 posts in 1173 days
#8 posted 03-05-2015 03:24 AM
I’d test good old shellac on a scrap and see what you think. I like the blonde or super blonde to keep the finish color pretty clear.
-- Lee
Paul Maurer
#9 posted 03-05-2015 10:05 PM
Glass cleaners often contain ammonia. Ammonia cleans both glass and shellac very well.
