Jewelery Box Finish
Forum topic by DonJ posted 05-27-2009 12:15 AM 1003 views 0 times favorited 5 replies Add to Favorites Watch
View DonJ's profile
250 posts in 3457 days
05-27-2009 12:15 AM
I am building a box with walnut, curly maple, and an inlay of red heart. I would like to pop the curly maple, but don’t have the time to do it right, as I’m delivering the box in a few days. I plan on using lacquer for the final coat(s). What would be the best process given the time limitations? I was thinking a quick coat of Seal a Cell from General Finishes, then the lacquer top coat. Any other suggestions? Thanks.
-- Don, San Antonio, TX
5 replies so far
View kolwdwrkr's profile
2821 posts in 3520 days
#1 posted 05-28-2009 06:50 PM
if you want to pop the grain wipe on a clear oil based stain like minwax. It has the necessary dryers in it just like a pigmented stain, but it is clear. Then just spray your sanding sealer and top coats like a normal job. HTH
View Chris Wright's profile
Chris Wright
540 posts in 3411 days
#2 posted 05-28-2009 07:52 PM
I’ve always had good results with just spraying a clear coat over figured wood. I think your plan is a good one.
-- "At its best, life is completely unpredictable." - Christopher Walken
View Jim Crockett (USN Retired)'s profile
852 posts in 3663 days
#3 posted 05-30-2009 09:02 PM
Clear / stain – isn’t this oxymoronic?
-- A veteran is someone who, at one point in his/her life, wrote a blank check made payable to "The United States of America," for an amount of "up to and including his/her life".
View Durnik150's profile
647 posts in 3251 days
#4 posted 05-31-2009 06:16 AM
I hope it’s not too late to throw out a suggestion. I was making a box with walnut and maple and wanted the maple to pop out as well. It ended up a little muted and I couln’t figure out why. It turns out that I hadn’t removed the sanding dust as thoroughly as I should. This allowed some of the walnut brown to darken the maple white. Take a little extra time to make sure all of the dust is off the project and you will have better results.
-- Behind the Bark is a lot of Heartwood----Charles, Centennial, CO
View Gene Howe's profile
Gene Howe
10242 posts in 3358 days
#5 posted 06-01-2009 03:44 PM
I’ve used BLO, Tung oil, or clear Watco alone. I’ve used those oils and topped them off with lacquer or clear poly. Then, Ive used just lacquer or poly without the oils. I can’t see any initial differences except in the time it took. Down the road, the oils applied alone lose their sheen and do need re-applications.
