dowels are TOO tight. What to do?
Forum topic by spaids posted 182 days ago 637 views 0 times favorited 39 replies Add to Favorites Watch
View spaids's profile
spaids
460 posts in 588 days
182 days ago
I have 1/2” dowels and a 1/2” forstner bit. The trouble is the dowels are VERY tight. I only need them to go in about 1/4 inch deep into the 1/2” forstner drilled holes.
First: is this common? My forstner bit set is a super el cheapo and I’m wondering if thats the root of my trouble.
Second: It is what it is so hows the best way to deal with it? I guessing sanding the ends of the dowels till the fit is the best way to go. Got any ideas for making this fast and or easy?
Thanks
-- Wipe the blood stains from your blade before coming in.
View GaryK's profile
GaryK
9530 posts in 883 days
182 days ago
Either sand or get a new 1/2” bit.
View SCOTSMAN's profile
SCOTSMAN
2244 posts in 480 days
182 days ago
try a half inch drill lip and spur is good and see if that helps.You need to make the hole bigger the dowel can’t be made smaller realistically easily so keep trying with a standard drill. Actually I never heard of anyone using a forstner for dowels although it’ should work fine what made you go down that route in the first place
View SplinteredBoard's profile
SplinteredBoard
51 posts in 501 days
182 days ago
Waid,
What did you do to get the walnut ‘bar’ centered on the middle of the back dowels? Did you get those together? Or are you just trying to get the dowel ends into one of the pieces first?
I would probably try sanding, but even then, there’s no room for expansion when you finally get them in the mortises.
Have you tried taking a sharp chisel to the ends? I’m not saying that’s the best way to go, but I’ve done it in the past. Yeah, it looked messy, but I got them in the mortises.
Again, though, think about the bar you have to slip over half of the dowels in the back…
-Rick
-- Splintered Board Podcast - Woodworker Un-extraordinaire
View tenontim's profile
tenontim
1319 posts in 639 days
182 days ago
It’s usually better to have them a little on the tight side, especially if you’re only driving them in 1/2”. Could be your dowels and not your bit. Most of the dowels you buy are imports and they are closer to a metric size than standard.
-- Tim -- http://tmuli.com
spaids
182 days ago
Scotsman: I a complete uneducated and inexperienced newcomer. So I just try the first thing that comes to mind. I needed flat bottom 1/2” holes and grabbed a forstner bit. If there is a better way I’d love to learn.
Rick: I’m good with that bar in the back. I took a piece of 1/4” dowel and wrapped it in sandpaper and chucked it up in my drill press. Since that back piece has holes all the way through I just slipped it on on the little dowel and sanded the inside of the wholes.
So is this the result of a cheap forstner set?
View Randy Sharp's profile
Randy Sharp
198 posts in 567 days
182 days ago
Waid, I’m facing the exact same situation myself (3/8” though). Was going to address it this evening and try to come up with a solution. Your’s is a great idea!! Thank you!!
BTW, I did put a caliper to the dowels and found that three coats of poly was just enough to make them too big for a comfortable fit.
-- Randy, Tupelo, MS ~ May I become more like the Master Carpenter every day.
16841 posts in 472 days
182 days ago
Hey spaids
Your problem could be that your dowels have been storied were it’s moist and have swelled a little bit so if you put them in a micro for a short time that might help and or your forstner bit is under size. I think you could have chucked your dowel in your drill press and sanded them as well. Good thinking on your aproach.
View printman's profile
printman
51 posts in 968 days
182 days ago
I don’t know when you were working on that project but with St. Louis weather (Rain every three or four days) maybe your dowels swelled from the humidity. Do you keep them in a dry place?
-- St. Louis - just a cut away from finishing!
spaids
182 days ago
Hey man I’m just down the road from you (O’Fallon) and I was working on this project this weekend and you know it was raining the whole time. Hmmmmm…
7638 posts in 1113 days
182 days ago
They should be snug, but if they really don’t fit, either your dowel is too big (moisture or poor manufacturing), or your hole is too small. :-)
There is no need for a flat-bottomed hole since the dowels are not going all the way to the bottom anyway. A standard twist drill or brad-point bit will be easier to work witj, and a little wiggle when drilling will give you a bit bigger hole to accept the dowel.
View Kindlingmaker's profile
Kindlingmaker
1471 posts in 421 days
182 days ago
I have bought several dowels from the same store at the same time and most of them were all different sizes, not by much but enough to want to turn some of them into kindling. ...also, if you heavily flute the dowels that too will add in their instalation and getting past that piston thing.
Dick, & Barb Cain
7036 posts in 1194 days
182 days ago
I some times crimp the dowels with a pliers to shrink them.
They will swell back to normal when glued.
This is the way they make biscuits for joining with a biscuit joiner.
View Damian Penney's profile
Damian Penney
1030 posts in 886 days
182 days ago
You might also try sawing/filing/chiseling some grooves in the dowel (if they don’t already have grooves) because if they are air tight, and there is nowhere for the air/glue to go…
View kerflesss's profile
kerflesss
132 posts in 263 days
182 days ago
Hi Spaids, Drill a hole in a piece of steel the same as the drilled hole and run you dowels through it. I use my vintage WWII drill gage which has all the sizes I need…
spaids
182 days ago
Randy,
What solution are you referring to? I’ve come up with nothing yet. That sandpaper wrapped down thing is only good for the through cuts and I think I got that idea from Rick.
There are some very good ideas on this thread. I think if I’m not able to crimp the ends I’ll try cutting the thinnest kerf I can in the end.
Should the kerf go with the grain or against it? I’m guessing the dowel could split over time if I do this wrong.
View mtnwild's profile
mtnwild
2015 posts in 422 days
182 days ago
I do what Dick and Barb said. Gives more glue surface too.
I usually touch up dowels before using. Soft wood dowels will swell. But I’m in the moist NW.
GaryK
182 days ago
Great idea Dick!
I never thought of that.
I don’t hardly ever use dowels, but I will remember that.
View FJPetruso's profile
FJPetruso
163 posts in 605 days
182 days ago
Hi Spaids…
I had a problem with oversized dowels when making one of my rojects. Since the dowels were oversized they didn’t thread properly. I found this item at the Japan Woodwoker. You might look into using one of these dowel rounding planes or make your own dowels with a router or molding head.
http://www.japanwoodworker.com/product.asp?s=JapanWoodworker&pf_id=99.017.04&dept_id=13621
-- Frank, Florissant, Missouri "The New Show-Me Woodshop"
View jcsterling's profile
jcsterling
68 posts in 480 days
182 days ago
I agree with Jim. Put the dowels in the microwave for about 15-20 seconds to get some of the swelling down.
-- John , Central PA , www.jcsterling.com
View Dan Lyke's profile
Dan Lyke
607 posts in 1020 days
181 days ago
Yeah, I have a Toast-R-Oven™ in the shop for biscuits and Dominos, but I’m betting tossing the dowel in an oven at 160-180F for a few minutes would probably solve your issue quickly and easily.
spaids
181 days ago
Hmmm I will be cooking up some Dowel casserole very soon.
3040 posts in 916 days
181 days ago
Don’t fit em in too tight or they could split your wood later whent he humidity shifts.
damhikt.
Biscuits can pucker the surface of your work too so a sloppy fit is better there too.
Randy Sharp
181 days ago
Waid,
I tried wrapping sandpaper around a dowel last night, using double-stick tape on a 1/4 dowel to help open a 3/8” through hole. On Oak, it was not worth the effort on 20 pieces. I resigned to re-drill my current 3/8” through hole with a 7/16 bit, but left about 1/16 of the hole at 3/8. In other words, I didn’t drill the entire hole with the 7/16 bit.
I found that I get a tight fit with the 1/16 to hold it in place, and the extra 1/16 on the rest of the hole gave me some glue area.
For the Fortsner “non-though” hole, I didn’t have a 7/16 bit, so I made it at 3/8 and will sand down the dowel for a snug fit, then glue. Since my depth is only 5/8” deep, this will not be a lot of work.
trophy
spaids
181 days ago
Randy
When I wrapped the dowel I used spray glue on both the dowel and the back of the strip of sandpaper. It worked well for what I was doing but it was tedious and time consuming. I only did it on 5 holes though.
Is that a Frisbee golf trophy? .... Nice!
View kimball's profile
kimball
51 posts in 192 days
180 days ago
Lie- Neilson has a dowel sizing plate.
Good Luck,
Kimball
180 days ago
NEVER BUY ANOTHER DOWEL!
http://www.fine-tools.com/duebelherstellung.htm
OR
http://www.leevalley.com/wood/page.aspx?c=2&p=52401&cat=1,180,42288
BOB
View Chris Wright's profile
Chris Wright
360 posts in 376 days
180 days ago
If you’re doweling joints, you could also check this out:
http://www.woodcraft.com/product.aspx?ProductID=146449&FamilyID=5410
It cuts the groves in the sides of the dowl, can also make it a little easier to tap into the hole.
-- "At its best, life is completely unpredictable." - Christopher Walken
spaids
180 days ago
Well this is how I took care of it.
Belt Sander
After closer inspection these dowels were NOT round. Go figure! So I decided that , although nuking em would have been quick and easy, sanding was merited.
Dick, & Barb Cain
180 days ago
Fluted dowels are better because they won’t hydraulic and split your board.
Crimping them with a mechanics plier is the same as fluting.
View Gary Fixler's profile
Gary Fixler
647 posts in 277 days
180 days ago
I don’t think I saw anyone recommend what I would do, which probably says a lot about the sanity of what I would do :) I’d chuck the dowels in my drill, hold some sand paper on the end, and drive them for a moment to sand the ends quickly.
-- Gary, Los Angeles, video game animator
Kindlingmaker
180 days ago
Gary I’m with ya there but I use the drill press and a sanding block, (when needed).
spaids
180 days ago
Hey guys thats funny! I did try that. I chucked one up in my drill press and ran it. It did work but for me it didn’t work great. If I had adjusted the drill speed maybe it would have worked better for me.
SCOTSMAN
180 days ago
Sorry I didn’t read your post properly I thought of dowelling full hidden dowels not just using the drill to make a tenon this is not dowelling as such then maybe it is just the slight difference between out languages technically yes it’s dowel rod. Anyway if I had read it correctly in the first place I would have reccomended what you eventually did your self.So you see your just like me a damn genius LOL well done there’s a bit of Scottish blood somewhere in your veins Bonnie lad LOLregards Alistair
View Greg's profile
Greg
223 posts in 203 days
180 days ago
I just drilled 84 holes for 42 dowels to edge glue a table top. Sheeesh! I’m buying a biscuit joiner tomorrow. I had to sand about 17 of the dowels to get a good fit. I bought a new brad point bit afterwards and it does make for a better fit but who’s to say what will happen when I buy my next bag of dowels. Too many variables. Best to make my own dowels.
-- Each and Every step of any project should be considered your masterpiece if you want the finished product to reflect the quality of your work. Greg Little
spaids
179 days ago
Aye Scotsman!
Greg… dude… 42 dowels to edge glue a table top! ouch. GET A BISCUIT JOINER! I’d say you earned it. My porter cable biscuit joiner would have done that job in about 5 minutes.
179 days ago
I have read repeatedly that our modern glues are stronger than the wood they join in most cases.
It is also suggested that dowels and biscuits be used for alignement rather than strength.
I just wonder if we are on the wrong track here with trying to snug up these dowels to compensate a weak joint?
spaids
179 days ago
Bob,
I have done a poor job explaining what I’m doing. You’re right about the strength issue and I too have heard the gospel of modern glues. I think if you are using dowels for alignment though, wouldn’t a correct fit be more important then in any other dowel use situation? If I was to glue up an edge glue situation I would use naive blind faith in my biscuit joiner. I say naive because of my lack of experience. In my situation here let me post a pick of my goal.
TSDC Desktop Organizer Contest Entry
I should have posted this right away! Sorry about that guys. Thanks for the tremendous support with this quesiton. I’ve gained a great deal of dowel tricks from this thread.
PS notice the smaller dowels in the sides. I placed those there for strength no alignment. I feared the strength of a glue joint alone there because there is only end grain to long grain contact.
179 days ago
I thought you were talking about these:
Turns out you are using these:
One is semi precison hardwood like beech etc the other is probably off shore from China and is approximate at best and most likely smells moldy if you sniff it.
It so much easier if you give us a pic before you ask a question so we can be more helpfull .
Dick, & Barb Cain
179 days ago
If you want a perfect, & strong edge to edge glue joint, get one of these edge to edge router bits.
You’ll never need dowels or biscuits again. I’ve glued a lot of things this way.
