Below are pictures of some jigs I've made & used over the years. Has I post new ones I'll provide a description of what each one is made to do & how it works. I have a boxes full jigs and fixtures because many of my carpentry & woodworking task require repetitive actions. I read through over half of the forum pages about jigs & fixtures available on this site. I'll try to post jigs & fixtures I've made that are different and unique and stay away from ones that are already so numerous that it seems pointless to just post more of them on the site.
This is a saw jig that I use to make radius cuts on the ends of beams. It can be used on 4x, 6x, etc… I make the cuts pretty much like you make cove cuts on the tables saw. I start very shallow dragging the saw across the end of the beam incrementally increasing the depth of the cut until desired depth has been reached. The final pass is made very slowly to achieve a smoother cut. The miter pictured is 22.5°. The radius of the cut is limited to the size sawblade used. This saw pictured has a 7.25" blade.
they do allot of corbel cuts around here
to go with the southwestern adobe look
but mostly with the bandsaw
which of course cant be done well
with long timbers
Yes bandsaws work well on the shorter corbels. I've seen other carpenters try to make similar cuts on the ends of beams with reciprocating saws, but the cuts are usually out of square, especially on thicker beams.
This method does make a cleaner, crisper cut.
Another big wood jig/fixture. I call this one the "aircraft carrier". It is what it resembles. It is made for use with a 16" beam saw. I know there probably are not a lot of fellow LJs that use large beam saws, but there are now more than 100,000 of us on the site. With spring/summer approaching here in the Northern Hemisphere I think that there will be quite a few people starting to think about future plans.
The fixture is for safely cutting 45° miters on the end of 6×6 post with a 16" beam saw. The pictures should pretty much make building one and use self explanatory for a typical carpenter/woodworker.
Thanks Andy, JAAune. I do love the model 77 Skilsaw, It's is my favorite circular saw. I have been know to use it like a power planer for a quick planning job when I didn't want to or didn't have the proper planer with me.
FYI, on the 2×6s pictured above, to cut the radius I used a "jigsaw" that Porter cable sells calling it a bayonet saw. It has a wide fixed base. I've had better luck with it vs. other jigsaws making clean cuts without the "walking"out of square cut experienced with some saws cutting a radius.
Thank you Blaine. old school sometimes is the only way I know. But I never turn down a better way. That's what makes this site such good place to visit. More ideas are a good thing.
Thanks Tim, How many passes? I don't know, a lot. An 1/8" per pass sounds about right. If you get greedy and try to go deeper you run the risk of kickback, or kickup in this case. Ether way you'll ruin the piece if it happens. Slow, linear pressure and steady speed across the grain are required. For the last pass I slow down the speed dragging the saw across the grain. This gives more cuts per inch making a smother cut.
I realize that it is hard to see in the picture of the first jig. I installed a piece of 90° wall angle, (the stuff you see around the room edge of an acoustic drop ceiling) on the jig for the Skilsaw table to ride on. I did this for wear reasons.
Related Threads
LumberJocks Woodworking Forum
2.5M posts
96K members
Since 2006
