Need Help Stabilizing Threaded Rod To Wooden Base For A Lamp
Forum topic by Tunalmelt posted 03-02-2015 04:14 PM 725 views 0 times favorited 2 replies Add to Favorites Watch
View Tunalmelt's profile
5 posts in 1165 days
03-02-2015 04:14 PM
Topic tags/keywords: lamps
I recently ordered
I am having a difficult time figuring out a way to stabilize the rod to the base. I drilled into a 1 inch thick piece of pine at 3/8 in which is size of rod and bored a hole at bottom at 1 1/4 inches to fasten a nut and washer. However I am trying to stabilize the base to the pipe using only one threaded side meaning not the entire length of the rod. I want to stack things on top of the rod so having it stable initially at the base is my main concern. I understand I could use a washer at both ends of the wooden base but I was hoping for a cleaner looking alternative. Any suggestions? Thank you!
2 replies so far
View Bill White's profile
Bill White
4882 posts in 3897 days
#1 posted 03-02-2015 04:50 PM
Have ya thought about some epoxy?
View Woodknack's profile (online now)
11324 posts in 2317 days
#2 posted 03-02-2015 08:39 PM
If you bought the kit with threading at both ends, it’s not meant to be free standing but go through a tall body and be secured on both ends, the body is then secured to the base.
-- Rick M,
