How do I clamp large panels
Forum topic by bluchz posted 185 days ago 563 views 0 times favorited 17 replies Add to Favorites Watch
View bluchz's profile
bluchz
143 posts in 269 days
185 days ago
Topic tags/keywords: question
I will soon be trying to clamp together a kitchen island top. The plan is to do it in 3 steps. Clamping 2 halves, let the glue dry, then clamping the 2 halves together. Now the big question. could i use pocket screws to hold the pieces together till the glue dries then remove them? I don’t have long enough clamps to hold the final glue together. I saw a jig once for a long counter glue up maybe i need to make one for a wide glue up? I would hate to spend $2-300 dollars on clamps all at once but i may have to.
2422 posts in 237 days
185 days ago
you can make temp. clamp with some planks ( 2×4 or whatever ) separated and atached together with same thikness
pieces as top and drive wedges on sides to bring glueup together , make as many as you want and reuse later or take apart and and make something else with wood .
. put wax paper or plastic wrap top and bottom betwen clamp and glueup
> —- |||||||||||||||||||||||||||||||||||||||| W———-
View SteveB's profile
SteveB
51 posts in 954 days
185 days ago
I have a pair of ten-foot clamps. They’re ten feet long because that’s the only length pipes the hardware store had. I really only needed eight feet. ;-)
Get a few pairs of pipe clamps, and use whatever length pipe you like. Put cauls on either side to keep the slabs aligned.
-- Steve B - New Life Home Improvement
16910 posts in 473 days
185 days ago
I’m wondering what kind of joinery and what kind of counter top. If this is pre made laminate counter top you connect from underneath with special bolts you rout out for . If wood you can screw some temporary blocks on the bottom and use small clamps to hold it together until the glue drys.
View Durnik150's profile
Durnik150
536 posts in 218 days
185 days ago
I picked up a tool to address this very problem (SURPRISE!). Rockler has a kit that is geared toward keeping flat glue ups flat. Now, I have to admit that I haven’t done a table top or cutting board since I got it (naturally). but it sure looks good. It consists of several plastic 90 degree angles strapped onto the workpiece by adjustable straps. The intent is to apply pressure inwards while giving the pieces nowhere to go. It was pretty cheap as far as tools go (around $30 if I recall correctly). Take a look and see if it might work for you.
-- Behind the Bark is a lot of Heartwood----Charles, Centennial, CO
bluchz
185 days ago
OK again i suffer from lack of detail. th peice will be made from SYP and is about 6 pieces 7-1/4” wide. The plan was to Biscuit joint them to keep ‘em in line and Pocket screw them until the glue dried.
185 days ago
you still need the pressure to hold the glue.
another method is to put 2 stops 1 either side of glue up , leaving about 1 or 2 inches and drive wedges to tighten them you can still do biscuit
and if upside down can do your screws , dont forget the plastic on work table
View degoose's profile
degoose
2006 posts in 251 days
185 days ago
David I agree with you, wedges were used by the ancients . to split and to clamp. Clamping pressure need not be great if the joints are tight ,, just enough to hold while the glue dries, with the internal clamping of the biscuits,
but by all means use pocket screws to pull it together,
BTW SYP is?
Durnik150
185 days ago
These are the clamps I was talking about above. I think they might just be what you need. They run $25-30 at Woodcraft but I’m sure Rockler will have a version of it as well.
They squeeze your panels from all four sides at the same time and the clamp itself holds the panel flat. Best of luck.
Double Bar Clamp
bluchz
185 days ago
SYP = southern yellow pine
View Sawdust2's profile
Sawdust2
1186 posts in 984 days
184 days ago
I looked at my July 2009 WOOD magazine just after reading your query.
It has a tip on making clamps that would easily solve your problem.
I tried to find it in WOOD online but was not able to do that.
View AeroClassics's profile
AeroClassics
11 posts in 263 days
167 days ago
If you need/want a modern mechanical clamp, then pipe clamps offer the least expensive way. Using a jig and a wedge is very effective. My question is how thick are these boards? If thick enough you can drill each board for a piece of all thread. On the boards next to the outside boards counter sink for the nuts. This will pull the boards together. Once dry you can remove the all thread or leave it in, depending on how much movement you expect. Pocket screws will be fine as long as you remove them when the top is dry. For what it is worth this is an excellent project for polyurethane glue.
Doug
-- Doug, Carrollton, TX. www.djswoodworks.com
View sweets's profile
sweets
34 posts in 226 days
166 days ago
Why would you want to remove the pocket screws after the glue dries?
-- Lee Cortez, South Louisiana
View KnotWright's profile
KnotWright
82 posts in 384 days
166 days ago
When I have a very large item I need to clamp, I resort to the ratchet straps you can get from Home depot and some very straight 2×4 stock. I cut the 2×4 stock short of the width of the item to allow for contact of the straps to the edge of the item. You can also “clip” the ends of the 2×4 at a 45 degree angle to allow for this contact. The 2×4’s keep the item from cupping when you tighten up the straps. I put a 2×4 on the top and bottom and run the strap around the 2×4’s. This keeps the ratchet and hooks from messing up the item being clamped. You will want to put some paper or plastic between the 2×4’s and the item to keep it from getting stuck while clamping.
Normally in my area you can get 4 of this ratchet clamps from Home Deport for $14.00.
-- James
View PurpLev's profile
PurpLev
2759 posts in 544 days
166 days ago
I usually will do like James does – 2×4s and a ratchet strap – I use those to transport lumber etc on my cars’ roof rack, so they are available for me to use. if not – Davids idea of 2×4 construction with wedges is a great technique – but if you just want to avoid making something – pipe clamps are a great way to go about it – they are as long as you can get a pipe (cheap) for them, and have the highest clamping pressure. you’ll need a clamp about every 12” or so, and you’re all set.
View Julian's profile
Julian
698 posts in 421 days
166 days ago
All you need to do is let the pocket screws do the work, and no clamps will be needed. Simple as that.
-- Julian, Park Forest, IL
View thebee's profile
thebee
20 posts in 510 days
166 days ago
I made some clamps you might be able to use, they are in my projects. I do not know how to put a link in this posting. Take a look they may work for you.
-- It is, what it is.
View Kindlingmaker's profile
Kindlingmaker
1475 posts in 422 days
166 days ago
I like bricks!
