Plunging a non-plunging straight bit...
Forum topic by Adamal posted 03-01-2015 06:44 PM 896 views 0 times favorited 7 replies Add to Favorites Watch
View Adamal's profile
Adamal
58 posts in 1905 days
03-01-2015 06:44 PM
I’ve got to cut some 1” long slots in a jig that I’m making. It’s for a box joint jig and the problem is, I don’t have any plunge straight bits. I’ve got a bunch of regular straight bits and I’ve use them for slots before, but only after I’ve cut the initial hole with a drill bit and then drop the piece down onto the router table.
It’s not an exact science and was wondering if there’s a better way to cut these slots without a plunge bit. I only need 1/4” diameter and about 1” long.
Thanks.
7 replies so far
View Bill White's profile
Bill White
4855 posts in 3865 days
#1 posted 03-01-2015 07:10 PM
Why not just buy a plunge bit? That would save some steps in the process.
Bill
-- bill@magraphics.us
17547 posts in 1761 days
#2 posted 03-01-2015 07:14 PM
Even some bits that are meant to plunge, such as a bowl bit don’t do it well. I usually move it forward a bit as I’m plunging which helps it plunge. You may be able to do this with your bit. Or like Bill said, get a bit. The spiral bits are good for this.
View JAAune's profile
JAAune
1780 posts in 2222 days
#3 posted 03-01-2015 07:54 PM
One of the most useful but silly tricks I learned during my short woodworking internship is that you can in fact plunge with a non-plunge bit. However, I do this with a handheld plunge router and a fence. Basically you just move the router back and forth along the fence while slowly plunging and it’ll plunge with ease.
In the CNC world, this is called “ramping.”
View Ghidrah's profile
Ghidrah
667 posts in 1127 days
#4 posted 03-01-2015 09:42 PM
or you could begin the cut before entering the wood then rise at the end.
-- I meant to do that!
Adamal
#5 posted 03-01-2015 09:48 PM
Thanks all.
I’ll have to buy some plunge bits. The thing is, my usual go-to spot for bits (MLCS) doesn’t have anything smaller than 3/8”. I know Whiteside has them, but I wanted to get this thing done today.
View JesseTutt's profile
JesseTutt
853 posts in 2015 days
#6 posted 03-01-2015 09:56 PM
try woodline usa (www.woodline.com).
View dawsonbob's profile
dawsonbob
2735 posts in 1660 days
#7 posted 03-01-2015 10:05 PM
Check Amazon. They have all different types by all the manufacturers. Usually pretty inexpensive, too.
-- Mistakes are what pave the road to perfection
