PVA glue - the elephant in the room
« back to Hand Tools forum
Forum topic by Benvolio posted 03-01-2015 12:40 AM 1186 views 0 times favorited 7 replies Add to Favorites Watch
View Benvolio's profile
Benvolio
148 posts in 1959 days
03-01-2015 12:40 AM
So I’m in the middle of a big glue up at the moment – about 50 jointed pallet member surfaces to be glued for a bench top. I was in the hardware shop and on the shelf, there’s the standard builders PVA and Gorilla glue sat next to each other…
now the timber for this 6’ x 4’ x 4’’ top only cost me £4 (about $7) and the glue is costing me £15…
So I’m thinking what I think most woodworkers have thought at least once – why not just use standard PVA for glue ups where fatigue and strength aren’t a huge issue?
What does `yellow` glue have that PVA doesn’t?
(I’m sure this has been asked before but I couldn’t find it searchin the site)
thanks
-- Ben, England.
7 replies so far
View MrUnix's profile
MrUnix
6768 posts in 2227 days
#1 posted 03-01-2015 12:53 AM
AFAIK, yellow and white glue are both PVA, although have different tack and set time depending on additives Gorilla glue on the other hand is a completely different animal (pun intended).
PS: I just use whatever is cheapest as long as water resistance isn’t needed (then I turn to titebond II/III or epoxy).
View Dan'um Style's profile
Dan'um Style
14173 posts in 4011 days
#2 posted 03-01-2015 01:12 AM
For a bench top I would use Gorilla Glue. I sure it would take a good pounding. I have been using it for Gorilla products years and years
and love the stuff. Of course I won a Gorilla Glue contest here back in the day. Won a whole box of Gorilla glues, tape and samples back in 2008.
http://lumberjocks.com/projects/9355
Click for details
View JAAune's profile
JAAune
1802 posts in 2344 days
#3 posted 03-01-2015 01:36 AM
Good old Elmer’s school glue works perfectly fine for anything that doesn’t need the extra water resistance of the newer PVA wood glues. I’ve used it in the past while building a nearly $20,000 dining table and had perfect confidence in its ability to hold up.
Now I’m using Titebond III. We’re doing a wide range of projects and some of them do need the water resistance plus I like the initial tack of the Titebond and it has the same open time. Elmer’s glue is runny and parts are more likely to slide when clamping them. Stocking two types of glue is a hassle so Titebond III is the choice. It’s purchased by the gallon.
View AlaskaGuy's profile
AlaskaGuy
4215 posts in 2337 days
#4 posted 03-01-2015 02:44 AM
Click for details
- Dan um Style
Gorilla Glue is a brand name. They make several different products. Which flavor of Gorilla Glue are you recommending???
View TheFridge's profile
TheFridge
9608 posts in 1514 days
#5 posted 03-01-2015 03:12 AM
It’s really a crapshoot with glue if you don’t need water resistance. I use tb2 & 3.
View Woodknack's profile
Woodknack
11821 posts in 2408 days
#6 posted 03-01-2015 07:44 AM
I’ve used all kinds of glue from white Elmers, yellow Elmers, all 3 Titebonds, generic yellow glue; outside water resistance and tack time they are all more than strong enough for wood. The yellow Elmers has the fastest tack time, nice when you aren’t trying to glue 50 things at once.
5000 posts in 2521 days
#7 posted 03-01-2015 01:25 PM
I’m struggling with the question: someone else mentioned it, I think yellow glue is PVA. Do I misunderstand? That said, it seems like ₤15 is an awful lot of glue, or at least an awful lot of money for glue.
